[Geomoose-users] WFS in GM3
Dan Little
theduckylittle at gmail.com
Mon Aug 28 14:03:53 PDT 2017
Does the WFS layer *draw* on the map? (Define some styles,and then add a
catalog item for it.)
I suspect a projections issue as well. The reason the query happens in 4326
is due to some MapServer projection bugs that I had found while doing the
dev work. The easiest way to handle it was to use 4326 for the query.
On Mon, Aug 28, 2017 at 3:32 PM, TC Haddad <tchaddad at gmail.com> wrote:
> I'm working my way through setting up GM3 with some local parcel data, and
> am having issues with the portions that use WFS. Here's what's happening:
> - local data draws fine
> - Identify uses WMS GetFeatureInfo, and works fine
> - Search and Select both use WFS and seem to generate valid queries. They
> do not return an error when used, but do return an empty set of results.
> troubleshooting:
> - Search: figured out that there was a hard-coded field name in search.js
> that wasn't mentioned in the docs, but after fixing that, I'm still not
> getting any results from search...
> - Select: seems to be passing valid coordinates in 4326 to the WFS. The
> data is in 3857. The data is drawing correctly so I'm assuming the map file
> is fine, but no results come back, so wondering about projection issues for
> this one...
> Any ideas where else I can look for issues?
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170828/f97c2f6c/attachment.html>
More information about the Geomoose-users
