[Geomoose-users] GeoMOOSE searching GeoNetwork metadata
Kevin Grootendorst kgrootendorst at gmail.com
Thu Feb 2 17:25:21 PST 2017
Thanks for this feedback Jim.
Would the current GeoMoose version 2.9.2 support this endeavor or have
features/functions been deprecated since then?
With respect to your second point, my client's GeoNetwork would not be
harvesting data from other catalogs, only an internal database.  I foresee
less complexity in terms of needing mapfiles generated on-the-fly to deal
with projection issues.
In hindsight though, do you think that the GeoMoose - GeoNetwork connection
was worth your time and effort?  Or do you believe that it makes more sense
just to keep the two applications separate?  Given the time and effort
involved, I'm torn between the viability and feasibility of this, versus
some sort of alternate solution.
Cheers,
Kevin
On Thu, Feb 2, 2017 at 10:46 AM, James Klassen <klassen.js at gmail.com> wrote:
> I wrote an extension connected GeoMoose to a CSW server (GeoNetwork) for a
> project maybe 5 years ago or so.  I had intended to release it but never
> got around to cleaning it up enough to not be project specific.  It would
> also take some work to bring it up to date with current GeoMoose.
> It was a tab that searched the catalog and then presented the results with
> options to view the metadata or if a WMS link was present in the metadata,
> add the layer to the map.  A download button would be possible if it could
> be derived from the metadata, but don't remember if I had that working.
> Add to Map required some trickery:
> 1) The Active/Visible layers extension was necessary to control the layers
> added from CSW.  The regular Catalog tab still works as normal but didn't
> know anything about the new layers.
> 2) (And this was the real stumbling block to me finishing the release.)
> Because the CSW server was cataloging many off site resources, I had no
> control over the WMS servers.  As such many didn't support the projection
> used by GeoMoose (at the only commonly available WMS projection was 4326
> which looks horrible on screen) so I wrote a ruby-mapscript program that
> generated a mapfile for MapServer on the fly (in RAM) that from the
> metadata info would connect to the remote WMS, find the best projection
> supoorted by the server, if necessary reproject it to the projection uses
> by GeoMoose and create a local WMS server that GeoMoose would use.
> On Feb 2, 2017 8:23 AM, "Kevin Grootendorst" <kgrootendorst at gmail.com>
> wrote:
> Dear list,
> I'm interested in using GeoMOOSE to ssearch and display layers from
> GeoNetwork. A user would be able to query GeoNetwork metadata from within
> GeoMOOSE, then have the option to display metadata, add the layer to the
> map, or download the layer.
> I think I have to implement Catalog Web Services in GeoNetwork and have
> GeoMOOSE connect to these web services.  I assume I'll have to write a
> JavaScript extension for GeoMOOSE, but JS is not my strength.
> Does any one have any insight into how to develop this connection?  I
> found a post from years ago that confirmed that the connection is possible,
> but there was no additional info.
> Cheers,
> Kevin
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170202/272ec2b2/attachment.html>
More information about the Geomoose-users mailing list
