[Geomoose-users] Issues with buffer lines not displaying with select features functionality and feature reports - GM 2.9.2
Mark Volz
MarkVolz at co.lyon.mn.us
Fri Mar 17 11:04:49 PDT 2017
Brent,
I figured out the issue. I had a type-o in my extent. Because of that no records were returned when I tried to create a feature report.
Sincerely,
Mark Volz, GISP
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Thursday, March 16, 2017 10:02 AM
To: Mark Volz <MarkVolz at co.lyon.mn.us>; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Issues with buffer lines not displaying with select features functionality and feature reports - GM 2.9.2
Mark,
You may want to try PHP debugging. Basically enable it by editing feature_report.php and set (on line 26):
$DEBUG = true;
then add statements like
if($DEBUG) {
error_log("Map Projection: ".$map_proj);
error_log("Input Projection: ".$projection);
through out the code.
The results will be put in php_errors.log in the same dir as feature_report.php
The other thing to check is the name of your unique key column of your dataset (is is PID or something else?).
Best Regards,
Brent Fraser
On 3/16/2017 7:23 AM, Mark Volz wrote:
Brent,
After I press the button to create the parcel report feature_report.php responds with a 500 error. I don’t see any popup. I also confirm that the demo does work using MS4W 3.2.1. I am having trouble debugging this issue but I presume that the problem has to do with one of the following:
*Perhaps I missed a file somewhere when I added my own projection.
*Perhaps my map file is too complicated, but I doubt that would be the case. Most of my layers are in one file so labels don’t collide.
*I don’t think I missed anything when I was configuring the settings for the feature report.
Thank You!
Sincerely,
Mark Volz, GISP
Sent: Wednesday, March 15, 2017 3:50 PM
To: Mark Volz <MarkVolz at co.lyon.mn.us><mailto:MarkVolz at co.lyon.mn.us>; geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Mark,
Sound like Mapscript is crashing. The demo (v2.9.2) works ok for me.
I can:
1. Display parcels
2. Click the Identify button, then click a parcel
3. The parcel info is displayed in the Identify tab, with a report link:
javascript:GeoMOOSE.startService('feature_report',%20{'PIN'%20:%20'130010001051',%20'src'%20:%20'parcels/parcels'})
4. Click the link and see the "Download File" dialog with three links:
View in new Window/Tab
Download
Close this Window
5. When I click the "View ..." link the PDF is shown in a new tab with the parcel in the PDF's map portion and the parcel info below it.
At what point do you get the "500" error?
Best Regards,
Brent Fraser
On 3/15/2017 9:25 AM, Mark Volz wrote:
Brent,
I am getting a 500 internal service error. I am also getting a similar issue with the demo as well.
Sincerely,
Mark Volz, GISP
Sent: Tuesday, March 14, 2017 5:38 PM
Feature Reports are very special (and I don't think the feature_report.php has been changed for 2.9.2). What specifically do you see (or don't see) when you try yo do an Identify->Feature Report?
Best Regards,
Brent Fraser
On 3/14/2017 9:23 AM, Mark Volz wrote:
Brent,
Thank you for your reply. It seems your thread from 2.7.1 and 2.8 dealt with issues when the projection the data layer, mapserver map file, and geoMOOSE openlayers do not match. In my case everything should be in the same projection, which is Lyon County Coordinates 103749. I think I did everything necessary to add my own projection, however it may be possible I missed a step.
Here is what I did to add my own projection:
1) Added a definition for <103749> to C:\ms4w\proj\nad\espg
2) Modified local_settings.ini to reference EPSG:103749, and the fields used for mailing labels
3) Updated C:\ms4w\apps\geomoose2\conf\feature_report\parcel.xml to reference my mailing labels fields
4) Updated the extent and projection in C:\ms4w\apps\geomoose2\htdocs\geomoose\config.js
5) Updated the extent and projection in C:\ms4w\apps\geomoose2\conf\mapbook.xml
6) Added EPSG103749.js to C:\ms4w\apps\geomoose2\htdocs\projections
7) Added EPSG103749.js to C:\ms4w\apps\geomoose2\htdocs\libs\proj4js\lib\defs as well
8) Included script type="text/javascript" src="projections/EPSG103749.js"></script> in geomoose.html
9) Set the mapserver .map file and all of the layers to ‘init=epsg:103749’
Everything appears to work except for feature reports and the polygon outline displaying the buffer on select features.
Thank You
Sincerely,
Mark Volz, GISP
Sent: Monday, March 13, 2017 6:26 PM
Mark,
I did some testing some time ago on v2.7.1 and v2.8. The behaviors I found may be related to what you are seeing. Have a look at the thread http://lists.osgeo.org/pipermail/geomoose-users/2015-July/005735.html
Best Regards,
Brent Fraser
On 3/13/2017 1:36 PM, Mark Volz wrote:
Hello,
I am still having issues trying to get the feature report and buffer on selected features functionality to work on my map. I am specifically wondering if anyone has had any success using a projection other than EPSG:3857.
Buffers:
At GeoMOOSE 2.9.2 the select feature function uses query.php. However on an older 2.6 application I noticed the select feature function used select.php instead.
*Do I need select.php to draw buffers in the select feature function?
*select.php attempts to create a spatial lite .db file. However, I cannot get this file to open in Mapserver
*I cannot get the mailing labels to work using select.php
Feature Reports:
I am also having issues with the feature report functionality. Is the feature report dependent on a certain projection?
Anyways, if anyone has had any luck configuring GM 2.9.2 with a different projection please let me know.
Thank You!
Sincerely,
Mark Volz
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170317/503895c6/attachment-0001.html>
More information about the Geomoose-users
