[Geomoose-users] How To Add Search Clarification
Dan Little theduckylittle at gmail.com
Wed Sep 6 09:14:46 PDT 2017
The best reference for styling is to look at the Mapbox GL Style spec.
That's what we're using to define styles.
No, you can't use PNG in the styling for a WFS layer.  PNG is a raster
format whereas WFS deals strictly with vectors.
On Wed, Sep 6, 2017 at 10:42 AM, Julson, Adam (MNIT) <
adam.julson at state.mn.us> wrote:
> I understand WMS is used for speed.  If the WFS layer is fast enough can
> we use that mapsource entry for Catalog/Identify/Search/Grid/Select to
> try and simplify the Mapbook?
> I have one test layer in the catalog as a WFS but styling is a little
> foreign.  Is there a way to use png in the styling for a wfs layer?
> Thanks!
> Adam
> *From:* Geomoose-users [mailto:geomoose-users-bounces at lists.osgeo.org] *On
> Behalf Of *Dan Little
> *Sent:* Wednesday, September 06, 2017 7:10 AM
> *To:* TC Haddad <tchaddad at gmail.com>
> *Cc:* GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
> *Subject:* Re: [Geomoose-users] How To Add Search Clarification
> Unfortunately, you need to have two <map-source> entries at this point.
> One for the WMS service and one for the WFS service.
> The search tool gets configured to point to the WFS <map-source> and the
> catalog item is pointed towards the WMS <map-source>.
> On Tue, Sep 5, 2017 at 8:52 AM, TC Haddad <tchaddad at gmail.com> wrote:
> Is it correct to say that both WMS and WFS versions should be together In
> a mapserver group ? That is the example in the demo, though the docs don't
> state it's required from what I saw...
> On Tue, Sep 5, 2017 at 6:05 AM Dan Little <theduckylittle at gmail.com>
> wrote:
> Another fix for today. :D
> Yes, you can use both at the same time.  There's no conflict in leaving
> the *layer* in the catalog that displays the search as the WMS-based
> version but the WFS configuration will need to be added next to it to add
> search capabilities.
> On Fri, Sep 1, 2017 at 11:47 AM, Reynolds, Michael J. (MNIT) <
> mike.reynolds at state.mn.us> wrote:
> I notice in the following How To doc:
> https://github.com/geomoose/gm3/blob/master/docs/howto/add-search.md
> It describes creating a map-source name="firestations-wfs".
> Then later we're adding a new search service, specifically:
> searchLayers: ['firestations/fire_stations'],
> Is that correct or should it be
> searchLayers: ['firestations-wfs/fire_stations']
> On another note, we'd like to use a search service on a mapserver layer
> that uses png images for each point and labels.  We see that search service
> is currently a wfs or mapserver-wfs thing and we're wondering if there's
> any way to mashup the two and get the best of both worlds.  Even if the wfs
> layer isn't styled at all but used to execute the search and the search
> service in turn makes sure the related mapserver wms layer is also on.
> Pair/mash/link?
> Thank you.
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170906/4559786c/attachment-0001.html>
More information about the Geomoose-users mailing list
