[Geomoose-users] GeoMOOSE 3.x and projections other than EPSG 3857
James Klassen
klassen.js at gmail.com
Fri May 22 13:19:10 PDT 2020
1) isn't a problem. You can configure other projections for user facing
numbers like the coordinate display or the measure tool. The actual map
and wms requests will still be in 3857.
2 and 3) Not sure what to tell you. If you really need caches then you
may need to duplicate them in various projections.
My experience at the county scale is I get good enough performance with
MapServer serving what are basically cloud optimized GeoTIFFs over WMS to
bother with caches. Then the clients can ask for whatever projection they
want.
Supporting multiple projections from the WMS server has always been need
for us because some people (CAD users) need to work in county coordinates
(with a fake epsg code) instead of UTM.
On Fri, May 22, 2020, 14:40 Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Hello,
> It is my understanding that GeoMOOSE 3.x works best with EPSG 3857 (Web
> Mercator). I understand Web Mercator is great when users want to combine
> backgrounds from multiple sources. However, I would like to still use my
> county projection for several reasons.
> 1) Our users are expecting the X,Y coordinate display to be in
> county coordinates.
> 2) Our Air Photos are natively stored in county coordinates. Not
> needing to reproject our air photos improves performance when building a
> cache. I realize I could build our cache ahead of time, however I would
> rather build the cache on the fly.
> 3) We use our cache for several purposes. Other applications we
> have depend on air photos in county coordinates. I do not want to build
> two caches for both coordinate systems.
> Please let me know if it is possible to use a coordinate system other than
> 3857. If we can use our own coordinate system then is it more or less
> difficult to configure compared to the GeoMOOSE 3.x series?
> Thank You!
> Sincerely,
> *Mark Volz, GISP*
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200522/4ea8b43c/attachment.html>
More information about the Geomoose-users
