[GeoNode-devel] uploaded layers
Simone Dalmasso simone.dalmasso at gmail.com
Wed May 20 23:33:05 PDT 2015
I think that they can be delete if I remember correctly. The save step
should not use the geoserver_upload anymore if the layer is not new or is
not flagged for overwrite.
https://github.com/GeoNode/geonode/blob/master/geonode/geoserver/signals.py#L65
2015-05-21 6:06 GMT+02:00 Matt Hanson <matt.a.hanson at gmail.com>:
> Layers uploade are first put in an uploaded folder, then uploaded again to
> GeoServer.
> A past dev version required the original file in the uploaded folder be
> there or else it caused all sorts of errors when you tried to do certain
> things (edit metadata, mess with thumbnails).   The thumbnail stuff is all
> cleaned up, but is there anything else tied to the files in the uploaded
> folder or can they be safely deleted?
> -matt
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150521/82fa4efb/attachment.html>
More information about the geonode-devel mailing list
