[GeoNode-devel] Getting my django app to save to postgis instead of the default database...
Simone Dalmasso
simone.dalmasso at gmail.com
Mon May 9 12:48:43 PDT 2016
Is all good except that once you have your data in geoserver the command is
not "importlayers" but "updatelayers" in order to get them in geonode.
Regards
2016-05-09 20:29 GMT+02:00 Dave Kennewell <davekennewell at gmail.com>:
> Thanks Simone,
> That gives me the confidence to use DATABASE_ROUTERS to store the data in
> "geonode_data".
> From here I can hopefully then import/configure it in geoserver, roughly
> following
> http://docs.geonode.org/en/master/tutorials/admin/loading_data_into_geonode/geoserver.html
> and finally create the layer in geonode using importlayers.
> I think that should work, but I welcome any advice from anyone if I'm
> naively missing any roadblocks.
> On 9 May 2016 at 21:19, Simone Dalmasso <simone.dalmasso at gmail.com> wrote:
>> Hi it is correct, geonode models don't describe the layer contents only
>> the Layer entity. the geonode Layer table is in the geonode database and
>> contain the layers description while the shapefile content is stored in
>> dedicated tables in geonode_data and is created by geoserver on layer
>> upload.
>> 2016-05-09 19:01 GMT+02:00 Dave Kennewell <davekennewell at gmail.com>:
>>> Hi all,
>>> I have a django app that harvests latitude and longitude as float
>>> numbers, together with some text, and stores them in a model. After syncdb,
>>> this happily writes to my "geonode" default database.
>>> But I want to plot this data in geoserver, and show it as a layer in
>>> geonode. So (I assume) I need to get the harvested data into the
>>> "geonode_data" postgis database.
>>> When I look into the django documentation for multiple databases
>>> <https://docs.djangoproject.com/en/1.7/topics/db/multi-db/#defining-your-databases>,
>>> it suggests I use DATABASE_ROUTERS to achieve this. Sounds reasonable.
>>> But when I search the geonode codebase for DATABASE_ROUTERS there is nothing
>>> going on
>>> <https://github.com/GeoNode/geonode/search?utf8=%E2%9C%93&q=DATABASE_ROUTERS>
>>> Is it correct that the only way data gets into a standard geonode
>>> datastore is directly via the upload app, and not via any models?
>>> Before I go down the DATABASE_ROUTERS rabbithole, I wanted to check if
>>> this is the correct way to get model data into the datastore, or am I
>>> missing something?
>>> Thanks for any help
>>> Dave
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160509/71eacad0/attachment.html>
More information about the geonode-devel
