[GeoNode-devel] [GeoNode-users] rest service connection
Marcelo Villarroel
raul.marcelo.villarroel.villazon at gmail.com
Tue May 24 09:35:34 PDT 2016
Hi Simone,
I just saw the service has this spatial reference
Spatial Reference: 102100 (3857)
Maybe GeoNode is not reading it as EPSG:900913?
Thank you,
On Tue, May 24, 2016 at 12:22 PM, Marcelo Villarroel <
raul.marcelo.villarroel.villazon at gmail.com> wrote:
> Hi Simone,
> Syntax in ALLOWED_HOSTS & PROXY_ALLOWED_HOSTS was Ok. Thanks for the
> advice. Connection message remains the same.
> The debug console shows 3 kind of errors:
> - Failed to load resource: the server responded with a status of 404
> (Not Found).
> - Failed to load resource: the server responded with a status of 403
> (Forbidden)
> - GeoExplorer.js:1660 Uncaught TypeError: Cannot read property 'wkid'
> of undefined
> Is it possible that ArcGIS service is comming without Coordinate System
> reference?
> Thank you,
> On Tue, May 24, 2016 at 10:53 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Hi,
>> the ALLOWED_HOSTS is only for your server name and it's not involved in
>> the remote server use. It should contain the name or IP of your geonode
>> server.
>> the PROXY_ALLOWED_HOSTS should look like ( '<host>', ) beware
>> the parenthesis.
>> In case it still don't work you can open the browser debug console and
>> see what request is issued.
>> hope this helps
>> 2016-05-24 16:48 GMT+02:00 Marcelo Villarroel <
>> raul.marcelo.villarroel.villazon at gmail.com>:
>>> Hi,
>>> Geonode, version 2.4b25, is installed in a linux server of my office.
>>> I´m connecting as superuser through local network.
>>> There are ArcGIS rest services I want to add. They are provided as:
>>> https://
>>> <host>/arcgis/rest/services/SMA/WebMap_Existente/MapServer/<name>
>>> I added this server in local_settings.py:
>>> ALLOWED_HOSTS= [ 'https://<host>/arcgis/services' ]
>>> PROXY_ALLOWED_HOSTS = [ 'https://<host>/arcgis/services' ]
>>> When I want to add a layer to a map:
>>> Layers/ Add layers / Add a new Server... / Type: ArcGIS REST Service
>>> (REST)
>>> URL: https://
>>> The message remains: Contacting server... and does not connect.
>>> Do you know if there is something I´m missing in the configuration file,
>>> or is something related to the ArcGIS service itself?
>>> Thank you.
>>> Regards,
>>> *R. Marcelo Villarroel V.*
>>> Ing. Civil, MSc.
>>> *Sistemas de Información Geográfica*
>>> Cochabamba, Bolivia.
>>> Cel.: (+591) 722 12346
>>> Mail: raul.marcelo.villarroel.villazon at gmail.com
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
> Ing. Civil, MSc.
Ing. Civil, MSc.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160524/62124fde/attachment-0001.html>
More information about the geonode-devel
