[GeoNode-devel] Geoserver connection issue
Michael Peterman mpetermangis at gmail.com
Tue Apr 4 17:31:19 PDT 2017
Hi Francesco,
Yes I ran that command. Output is:
---> pavement.setup
---> pavement.setup_geoserver
rmtree geoserver/data
GeoNode development environment successfully set up.If you have not set up
an administrative account, please do so now. Use "paver start" to start up
the server.
Geoserver is version 2.7.4 on Java  1.7.0_121 (OpenJDK 64-Bit Server VM)
Any other ideas for what I can try?
Thanks again,
Michael
On Tue, Apr 4, 2017 at 1:46 AM, Francesco Bartoli <xbartolone at gmail.com>
wrote:
> Dear Micheal,
> did you run the command “sudo paver setup” ? If not what geoserver did you
> install?
> Francesco
> Il giorno 04/apr/2017, alle ore 01:39, Michael Peterman <
> mpetermangis at gmail.com> ha scritto:
> Hi,
> I am installing a custom copy of Geonode 2.4, as per these instructions:
> http://docs.geonode.org/en/latest/tutorials/install_and_
> admin/geonode_install/install_geonode_application.html
> I pulled from this git branch: https://github.com/GeoNode/geonode.git
> --branch 2.4.x
> and installed on a fresh copy of Ubuntu 14.04 64-bit.
> Everything appears to work fine, but after finishing the installation, the
> connection between Geoserver and Postgres seems to be broken. Any data that
> I try to upload to Geonode gives this error: "An exception occurred loading
> data to PostGIS- java.io.IOException: Error occurred creating table"
> The logs in Geoserver show a series of exceptions like this:
> 2017-04-01 23:55:40,930 WARN [geonode.security] - Error connecting to the
> GeoNode server for authentication purposes
> org.springframework.security.authentication.AuthenticationServiceException:
> Communication with GeoNode failed (GeoNodeSessionAuthToken)
> Caused by: java.net.SocketTimeoutException: Read timed out
> I am using the same credentials for the Postgres account (geonode /
> geonode) that are in the instructions.  Geoserver, Postgres, and Geonode
> are all hosted on the same machine.
> Thanks in advance to everyone, I really appreciate all the effort that has
> gone into this project.
> Mike
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170404/94dde6a8/attachment.html>
More information about the geonode-devel mailing list
