[GeoNode-devel] Integrity error
Francesco Bartoli
xbartolone at gmail.com
Wed Dec 13 14:44:38 PST 2017
You can find specific documentation for installing it on Centos 7 here http://docs.geonode.org/en/master/tutorials/install_and_admin/setup_on_centos/index.html
Hope this helps
Francesco
Il giorno 13/dic/2017, alle ore 16:52, PERDRIEAU Mathieu <Mathieu.PERDRIEAU at eau-loire-bretagne.fr> ha scritto:
> The 2.6 works only under docker? Or you can install on RedHat Server ?
> On this version, is this problem resolved?
> Regards,
> De : Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
> Envoyé : mercredi 13 décembre 2017 09:54
> À : PERDRIEAU Mathieu
> Cc : geonode-devel at lists.osgeo.org; geonode-users-bounces at lists.osgeo.org
> Objet : Re: [GeoNode-devel] Integrity error
> I suggest you to install the 2.6 on a clean environment. the 2.5 was a dev version and the 2.6 contains several fixes, probably also this one.
> Best regards
> 2017-12-13 9:48 GMT+01:00 PERDRIEAU Mathieu <Mathieu.PERDRIEAU at eau-loire-bretagne.fr>:
> Hello,
> On my server, I put Geonode 2.5. It was installed in March 2017.
> But my problem is not in the version, but an error in the Geonode code. When I add a new keyword in the documents, it wants to insert it with a depth to null. But this value must be not null in the database. And I also have the impression that the value of the path is not calculated. Do you know where these actions are done? and what modification can I make?
> In addition, do you have the conceptual model of the data?
> Regards
> Mathieu PERDRIEAU
> Envoyé : mercredi 13 décembre 2017 09:02
> 2.5 is not available. Do you have the 2.6? How did you install it?
> 2017-12-12 13:48 GMT+01:00 PERDRIEAU Mathieu <Mathieu.PERDRIEAU at eau-loire-bretagne.fr>:
> Hi ,
> Escuse me, I made a typing error. My geonode run under version 2.5. It is stable?
> The error comes from the hierachialkeywords table, the depth value is null. I do not understand why.
> Regards,
> Mathieu PERDRIEAU
> Envoyé : mardi 12 décembre 2017 11:07
> Cc : geonode-users at lists.osgeo.org
> Hi, geonode 2.9 (master) is considered unstable, the suggestion is to use the stable one 2.6 or maybe the 2.7 which is well shaped. We will check this for sure before the release.
> Regards
> 2017-12-12 9:20 GMT+01:00 PERDRIEAU Mathieu <Mathieu.PERDRIEAU at eau-loire-bretagne.fr>:
> Hello all,
> Currently I am having a problem with GeoNode. I use geonode 2.9
> My issue is the following :
> When I want to add a new keyword to a document I get the following error:
> ERROR: A NULL value violates the NOT NULL constraint in the depth column
> DETAIL: The failed line contains (71, TestDocumentV2, testdocumentv2_1,, null, 0)
> This error only occurs with the documents, did you already meet it? Do you have a solution ?
> Thank you
> Mathieu PERDRIEAU
> Agence de l'eau Loire-Bretagne
> 9 avenue Buffon - CS 36339 - 45063 ORLEANS CEDEX 2
> Tél. : 02 38 51 73 73
> Etablissement public du ministère chargé du développement durable
> www.eau-loire-bretagne.fr
> Pour un bon état des rivières, lacs, nappes et littoral, ensemble, prenons soin de l'eau !
> geonode-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20171213/6e1e4e0d/attachment-0001.html>
More information about the geonode-devel
