[GeoNode-devel] GeoNode for map based search
Rob Atkinson
robatkinson101 at gmail.com
Sun Dec 24 12:39:16 PST 2017
Hi Varun
This is partial answer, which is that whilst working on another codebase
that uses geonode i am faced with creation of extension modules that will
be designed to work with base geonode. In the coming months i hope to help
refine or publish documentation on how to package installable extensions. I
had something working with the old ansible install process.. now i need to
update it to support docker environment.
I have started to work thruough requirements at
https://github.com/MapStory/mapstory/wiki/Update-Use-Cases
If anyone else can point to documentation for this, or identify where it
should be, imho it ought to be raised as a priority documentation issue as
it is at the heart of the community process now the core is maturing.
Rob Atkinson
On 25 Dec 2017 06:34, "varun shah" <varun.shah196 at gmail.com> wrote:
> Hi!
> I want to build a web application which supports map based search, and I
> was wondering if I can do it via GeoNode.
> I have a custom shape file, which I wish to upload and display as a map,
> along with the feature information. This can be readily achieved via
> GeoNode.
> However, I also want users to be able to select a particular area of the
> map and then display only the features in that area, or take input
> coordinates and show features in the specified area, and several such small
> changes.
> I could not find documentation on how to customise the GeoNode application
> for these. Specifically, I want to know how can I take the coordinates
> selected on map in my program as input; and how can I display only a small
> subset of features in the map?
> Is this achievable via GeoNode? If yes, a link to reference/documentation
> would be a great help.
> Thank you!
> Regards,
> Varun Shah
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20171225/ee28c8aa/attachment.html>
More information about the geonode-devel
