[GeoNode-devel] Allow contrib apps to extend "site base"
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Feb 15 06:46:28 PST 2017
Dear all,
please provide feedbacks and comments to this issue:
https://github.com/GeoNode/geonode/issues/2910
"As a developer I need GeoNode "contrib" apps to be able to extend and
override (if needed) the GeoNode "site_base" template.
Currently this is not possible since "site_base.html" takes precedence on
every other template of GeoNode apps.
The solution I propose to solve this issue is to create a new
"base/geonode_base.html" basically empty and make all other apps extend
this one instead of "site_base.html".
Other than this the order of "INSTALLED_APPS" must be revised in order to
allow contribs to be scanned before the other apps.
In this way and the automatic improved templating system of Django 1.8+, it
is possible to override / extend the site_base.html template from a contrib
app."
Take a look at this Pull Request with an implementation proposal
https://github.com/GeoNode/geonode/pull/2912
As you may notice such change doesn't do basically anything except allowing
apps to extend "geonode_base" instead of "site_base" as explained in the
Issue text.
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170215/a1fedccc/attachment.html>
More information about the geonode-devel mailing list
