[GeoNode-devel] Where to put OSM Import Script?
Patrick Dufour
pjdufour.dev at gmail.com
Mon Mar 27 14:10:06 PDT 2017
Good afternoon,
For a downstream project, I've created a script to import OSM extracts into
GeoNode and would like to share it back to the community. It depends on
some recent improvements to importlayers and uses a version of the *.ini
files from osm-extract. I'd like to here your thoughts on where I should
commit this code. As I see it there are 3 options.
(1) add `scripts/osm` folder to GeoNode/geonode
(3) add to downstream geonode-project repo
(2) create completely separate repo and then use ansible to clone to target
machine
Thanks! :)
Reference links:
https://github.com/ftf-geonode/ftf_geonode/blob/master/scripts/import_osm.py
https://github.com/ftf-geonode/ftf_geonode/tree/master/osm/conf
https://github.com/malawigeospatialtools/osm-extract
Regards,
Patrick Dufour
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170327/70b201cb/attachment.html>
More information about the geonode-devel
