[GeoNode-devel] GeoNode Contrib App metadataxsl On By Default
Jeffrey Johnson jeff at terranodo.io
Wed Mar 29 07:17:41 PDT 2017
Hi Guys,
We actually had a client ask us why this form is different than the full
metadata detail page and if they could be the same.
I would prefer if this is default functionality that it be moved to core.
Jeff
On Wed, Mar 29, 2017 at 1:56 AM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hi guys,
> that module can be turned off or moved to core, how you prefer.
> This is part of the work done on advanced metadata editor. This module
> allows you to have a nicer previews of metadata, rendered through an easily
> customizable XLS template, like the example below
> [image: Inline image 1]
> The logic for the preview recognizing if the module is activated or not
> falling back to old one, is still there; therefore we can just disable it
> by default.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> github <https://github.com/afabiani?tab=overview>
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax:     +39 0584 1660272 <+39%200584%20166%200272>
> mob:   +39 331 6233686 <(331)%20623-3686>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Wed, Mar 29, 2017 at 9:19 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> I agree it should be off. Not sure what it does either :)
>> 2017-03-29 6:32 GMT+02:00 Patrick Dufour <pjdufour.dev at gmail.com>:
>>> All --
>>> I noticed that the geonode.contrib.metadataxsl was turned on by default
>>> in settings.py.  Was this a typo or intentional?  The previous "standard"
>>> around GeoNode contrib apps was that they would all ship with GeoNode, but
>>> would be turned off by default.
>>> Sorry, I'm not really sure what that contrib app does.  If
>>> `geonode.contrib.metadataxsl` is needed for the normal function of GeoNode
>>> is should be promoted out of a contrib app to a first-level app, right?
>>> Thanks!
>>> Regards,
>>> Patrick Dufour
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170329/19ba778c/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170329/19ba778c/attachment-0001.png>
More information about the geonode-devel mailing list
