[GeoNode-devel] Few notes on GeoNode branch 2.7.x
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri May 5 08:19:00 PDT 2017
Dear all,
recently I have forked from master a branch 2.7.x of GeoNode.
I'm writing some lines here in order to provide you some glance on the work
there and what it is containing.
1. First point, 2.7.x is aligned with ALL commits on master and 2.6.x
*except* the new notification and pubsub stuff which is still a work in
progress
2. Secondly, 2.7.x works against GeoServer 2.10.x with a first support for
QGis styles. The support is not yet full compliant on GeoServer side, but
nevertheless you can create your style on QGis client, export is as an SLD
(for rasters you will need to use the SLD4Raster plugin) and import it
directly on GeoServer. With minor manual editing it will result in
something almost identical to QGis. *WARNING* there are limitations. Please
refer to GeoServer documentation about that.
3. 2.7.x has improvements and fixes oriented to *stabilization". It is
constantly tested on real use case, maintained and updated in order to
improve performances, functionalities and reliability.
As soon as possible the idea would be to allow the master become 2.8.x+ and
2.7.x next candidate for the GeoNode release.
Long story short, please use it, test it and let's have a plan for pushing
forward further GeoNode releases.
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
github <https://github.com/afabiani?tab=overview>
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170505/7029f818/attachment.html>
More information about the geonode-devel mailing list
