[GeoNode-devel] Few notes on GeoNode branch 2.7.x
Simone Dalmasso
simone.dalmasso at gmail.com
Mon May 8 01:31:30 PDT 2017
Thanks Alessio.
+1
2017-05-05 17:19 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it
> Dear all,
> recently I have forked from master a branch 2.7.x of GeoNode.
> I'm writing some lines here in order to provide you some glance on the
> work there and what it is containing.
> 1. First point, 2.7.x is aligned with ALL commits on master and 2.6.x
> *except* the new notification and pubsub stuff which is still a work in
> progress
> 2. Secondly, 2.7.x works against GeoServer 2.10.x with a first support for
> QGis styles. The support is not yet full compliant on GeoServer side, but
> nevertheless you can create your style on QGis client, export is as an SLD
> (for rasters you will need to use the SLD4Raster plugin) and import it
> directly on GeoServer. With minor manual editing it will result in
> something almost identical to QGis. *WARNING* there are limitations. Please
> refer to GeoServer documentation about that.
> 3. 2.7.x has improvements and fixes oriented to *stabilization". It is
> constantly tested on real use case, maintained and updated in order to
> improve performances, functionalities and reliability.
> As soon as possible the idea would be to allow the master become 2.8.x+
> and 2.7.x next candidate for the GeoNode release.
> Long story short, please use it, test it and let's have a plan for pushing
> forward further GeoNode releases.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> github <https://github.com/afabiani?tab=overview>
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax: +39 0584 1660272 <+39%200584%20166%200272>
> mob: +39 331 6233686 <(331)%20623-3686>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170508/e371894a/attachment.html>
More information about the geonode-devel
