[GeoNode-devel] Group Categories improvement
Jonathan Doig
j.doig at unsw.edu.au
Mon May 22 16:43:05 PDT 2017
Hi Cezary
A few questions. Why category and not keyword? Why for groups and not for everything (layers, maps, documents, users)? Is there any relationship between group category and existing ISO19115 TopicCategory for layers?
At some point the data model offered in the base Geonode platform risks getting overloaded. Imho that is a risk here.
At my work I have been exploring the use of semantics with Rob Atkinson, to add arbitrary yet precise knowledge about resources to aid discovery and use. Semantics might be a better way to approach this as it is open and extensible without adding baggage. From the UI that might look more like an extended keyword feature that uses, and allows extension of, published vocabularies.
Regards
Jonathan
From: geonode-devel [mailto:geonode-devel-bounces at lists.osgeo.org] On Behalf Of Alessio Fabiani
Sent: Tuesday, 23 May 2017 12:39 AM
To: Cezary Statkiewicz <cezary.statkiewicz at geo-solutions.it>
Cc: geonode-devel <geonode-devel at lists.osgeo.org>
Subject: Re: [GeoNode-devel] Group Categories improvement
+1
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
github<https://github.com/afabiani?tab=overview>
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it<http://www.geo-solutions.it/>
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
On Mon, May 22, 2017 at 4:29 PM, Cezary Statkiewicz <cezary.statkiewicz at geo-solutions.it<mailto:cezary.statkiewicz at geo-solutions.it>> wrote:
I'd like to add group categories feature to GeoNode. Here's GNIP: https://
github.com/GeoNode/geonode/issues/3083<http://github.com/GeoNode/geonode/issues/3083>
Any feedback is welcome!
BR,
Cezary Statkiewicz
Regards,
Cezary Statkiewicz
Cezary Statkiewicz
Senior Software Engineer
GeoSolutions S.A.S.
Italy
phone: +39 0584 962313<tel:%2B39%200584%20962313>
fax: +39 0584 1660272<tel:%2B39%200584%201660272>
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo
dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse,
costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
geonode-devel mailing list
geonode-devel at lists.osgeo.org<mailto:geonode-devel at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170522/d1382300/attachment-0001.html>
More information about the geonode-devel
