[GeoNode-devel] 502 Bad Gateway when saving map
Dimitris Karakostis
karakostis.dimitris at gmail.com
Wed May 24 04:49:45 PDT 2017
Hello everyone,
I am getting a 502 Bad Gateway error when I try to save a map, which has
remote layers.
The layers come from a remote geoserver and they are created as indexed
(not as cascaded).
They are displayed correctly in the layer_detail/map_detail pages and I can
also print them (I have configured the yml file of mapfish). Moreover, I
have modified the settings.py file and added the host name in the
PROXY_ALLOWED_HOSTS.
When I create a map, the layers are displayed correctly but I can not save
the map. I get:
"The server returned an error: 502 Bad Gateway"
If I try to load the layers from the remote server manually using the "add
layer" tool in geoexplorer, then everything works correctly and the map is
saved.
As I understand this must be a network issue. Anyone has experienced
something similar?
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170524/66a98e39/attachment.html>
More information about the geonode-devel
