[GeoNode-devel] Issue when installing development environment from 2.7 branch
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Sep 7 03:18:36 PDT 2017
Try to pip uninstall all owslib packages you are on the system
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
On Thu, Sep 7, 2017 at 12:13 PM, Dimitris Karakostis <
karakostis.dimitris at gmail.com> wrote:
> Hello everyone,
> Recently I tried to install a new dev environment using the branch 2.7 but
> I keep getting an error related to OWSLib:
> "Could not find a version that satisfies the requirement
> OWSLib==0.14-dev"
> I checked the requirements.txt and I see that the OWSLib package is
> commented out.(https://github.com/GeoNode/geonode/blob/2.7.x/
> requirements.txt)
> I actually uncommented it and rerun the installation but I keep getting
> the same error. I tried to use the master branch as well but there is the
> same.
> Everything works well with 2.6 releases but 2.6 uses a previous version of
> OWSLib as well. Does anyone has similar issues?
> I would like to make some contributions so I guess its better if I work on
> 2.7 or master.
> Thanks
> Cheers
> Dimitris
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170907/bf228df8/attachment.html>
More information about the geonode-devel
