[GeoNode-devel] Clarifications on GeoNode branches, version numbers and deb packages
Paolo Corti pcorti at gmail.com
Thu Sep 7 07:15:13 PDT 2017
Hi
thanks for the explanation, Alessio.
I am not familiar with the release process, so I have a newbie
question: we are currently submitting PR vs master. Who is in charge
of the process to do a PR and merge from master to 2.7.x (and then to
2.8.x)? Or there is a script for this purpose?
thanks!
p
On Thu, Sep 7, 2017 at 4:22 AM, Alessio Fabiani
<alessio.fabiani at geo-solutions.it> wrote:
> Dear all,
> after a talk with Simone Dalmasso, which clarified to me how GeoNode project
> manages versioning and branchning, I'm going to summarize here the current
> status on this topic on the next steps.
>  - GeoNode odd version number are considered "unstable", which means they
> must be tested before promoted to a stable one. Therefore currently the
> 2.7.x is unstable and after the testing cycle it will be promoted to 2.8.x
> - GeoNode branch 2.7.x will contain versions which will be published to
> Launchapd and Pypi. Currently the version we need to release on
> "ppa:geonode/unstable" should be the "2.7.0.alpha.0"
> - GeoNode "master" branch should instead be bumped to 2.9dev version
> - After the testing cycle, once the 2.7.x will be considered stable, we will
> need to bump it to 2.8.0 and release on "ppa:geonode/testing" while in alpha
> and beta and "ppa:geonode/stable" when in rc and final state
> Did I miss something? Any other consideration or things to add?
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
> for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
> file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
> via e-mail e di procedere alla distruzione del messaggio stesso,
> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
> finalità diverse, costituisce comportamento contrario ai principi dettati
> dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender does
> not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-devel mailing list
