[GeoNode-devel] Clarifications on GeoNode branches, version numbers and deb packages
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Sep 7 07:22:42 PDT 2017
As far as I know currently no one is "officially" in charge. It is based on
volunteering. No script to automatically switch versions, just for
publishing and create Git Tags.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Thu, Sep 7, 2017 at 4:15 PM, Paolo Corti <pcorti at gmail.com> wrote:
> Hi
> thanks for the explanation, Alessio.
> I am not familiar with the release process, so I have a newbie
> question: we are currently submitting PR vs master. Who is in charge
> of the process to do a PR and merge from master to 2.7.x (and then to
> 2.8.x)? Or there is a script for this purpose?
> thanks!
> p
> On Thu, Sep 7, 2017 at 4:22 AM, Alessio Fabiani
> <alessio.fabiani at geo-solutions.it> wrote:
> > Dear all,
> > after a talk with Simone Dalmasso, which clarified to me how GeoNode
> project
> > manages versioning and branchning, I'm going to summarize here the
> current
> > status on this topic on the next steps.
> >  - GeoNode odd version number are considered "unstable", which means they
> > must be tested before promoted to a stable one. Therefore currently the
> > 2.7.x is unstable and after the testing cycle it will be promoted to
> 2.8.x
> > - GeoNode branch 2.7.x will contain versions which will be published to
> > Launchapd and Pypi. Currently the version we need to release on
> > "ppa:geonode/unstable" should be the "2.7.0.alpha.0"
> > - GeoNode "master" branch should instead be bumped to 2.9dev version
> > - After the testing cycle, once the 2.7.x will be considered stable, we
> will
> > need to bump it to 2.8.0 and release on "ppa:geonode/testing" while in
> alpha
> > and beta and "ppa:geonode/stable" when in rc and final state
> > Did I miss something? Any other consideration or things to add?
> > Regards,
> > Alessio Fabiani
> > @alfa7691
> > GeoSolutions S.A.S.
> > Italy
> > http://twitter.com/geosolutions_it
> > AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> > Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i
> > file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> > utilizzo è consentito esclusivamente al destinatario del messaggio, per
> le
> messaggio
> > senza esserne il destinatario, Vi preghiamo cortesemente di darcene
> notizia
> > via e-mail e di procedere alla distruzione del messaggio stesso,
> divulgarlo
> > anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo
> per
> > finalità diverse, costituisce comportamento contrario ai principi dettati
> > dal D.Lgs. 196/2003.
> > The information in this message and/or attachments, is intended solely
> for
> > the attention and use of the named addressee(s) and may be confidential
> or
> > proprietary in nature or covered by the provisions of privacy act
> > (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> > Code).Any use not in accord with its purpose, any disclosure,
> reproduction,
> > copying, distribution, or either dissemination, either whole or partial,
> is
> > strictly forbidden except previous formal approval of the named
> > addressee(s). If you are not the intended recipient, please contact
> > immediately the sender by telephone, fax or e-mail and delete the
> does
> > made after they were sent or for other risks which arise as a result of
> > e-mail transmission, viruses, etc.
> > geonode-devel mailing list
> > geonode-devel at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170907/b93de4fe/attachment.html>
More information about the geonode-devel mailing list
