[GeoNode-devel] Issue when installing development environment from 2.7 branch
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Sep 7 07:27:16 PDT 2017
Currently 0.14dev fixes some owslib issues not yet released. We can revert
them to 0.14 but we will lose those ones.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Thu, Sep 7, 2017 at 4:24 PM, Dimitris Karakostis <
karakostis.dimitris at gmail.com> wrote:
> This actually was it. But there are some new errors I will need to solve.
> If it makes sense I can make a pull request with the OWSLib=0.14 both in
> setup.py and requirements.txt.
> Cheers and thanks again.
> On Thu, Sep 7, 2017 at 2:58 PM, Simone Dalmasso <simone.dalmasso at gmail.com
> > wrote:
>> Dimitris, it's because the dependency is in the setup.py
>> https://github.com/GeoNode/geonode/blob/2.7.x/setup.py#L92
>> so if you installed the 0.14 you can comment that line, test and if it
>> works make a PR with the dependency fix both in setup.py and
>> requirements.txt ^^ :D
>> ty
>> 2017-09-07 14:51 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions
>> .it>:
>>> Thing is, that version it is not yet published on pypi, therefore it
>>> should be downloaded from git directly.
>>> Quite strange your pip utility does not do it automatically. Do you have
>>> the latest pip version? Try with "pip install pip --upgrade" to get the
>>> 9.0.1+ one.
>>> Otherwise you will need to revert back to older versions and thus
>>> manually modify requirements.txt and setup.py
>>> Regards,
>>> Alessio Fabiani
>>> http://goo.gl/it488V for more information.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>>> 55054  Massarosa
>>> (LU)
>>> Italy
>>> phone: +39 0584 962313 <+39%200584%20962313>
>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>>> http://twitter.com/geosolutions_it
>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>> principi dettati dal D.Lgs. 196/2003.
>>> The information in this message and/or attachments, is intended solely
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>> copying, distribution, or either dissemination, either whole or partial, is
>>> strictly forbidden except previous formal approval of the named
>>> addressee(s). If you are not the intended recipient, please contact
>>> immediately the sender by telephone, fax or e-mail and delete the
>>> made after they were sent or for other risks which arise as a result of
>>> e-mail transmission, viruses, etc.
>>> On Thu, Sep 7, 2017 at 2:44 PM, Dimitris Karakostis <
>>>> Thanks guys,
>>>> I uninstalled owslib (also checked for remaining files in
>>>> site-packages). It seems everything is deleted properly but still I keep
>>>> getting the same error message:
>>>>  Could not find a version that satisfies the requirement
>>>> OWSLib==0.14-dev (from GeoNode==2.7.dev20170906114728) (from versions:
>>>> 0.1.0, 0.2.0, 0.2.1, 0.3, 0.3.1, 0.4.0, 0.5.0, 0.5.1, 0.6.0, 0.6.1, 0.7.0,
>>>> 0.7.1, 0.7.2, 0.8.0, 0.8.1, 0.8.2, 0.8.3, 0.8.4, 0.8.5, 0.8.6, 0.8.7,
>>>> 0.8.8, 0.8.9, 0.8.10, 0.8.11, 0.8.12, 0.8.13, 0.9.0, 0.9.1, 0.9.2, 0.10.0,
>>>> 0.10.1, 0.10.3, 0.11.0, 0.11.1, 0.11.2, 0.12.0, 0.13.0, 0.14.0) No
>>>> matching distribution found for OWSLib==0.14-dev (from
>>>> I also tried to install OWSLib==0.14 separately. It is installed
>>>> successfully but when I try to install the rest of the requirements, I get
>>>> the same error.
>>>> I will keep trying and write here if I find something.
>>>> On Thu, Sep 7, 2017 at 1:24 PM, Simone Dalmasso <
>>>> simone.dalmasso at gmail.com> wrote:
>>>>> Dimitris I see in pypi there's owslib 0.14 try to pip install
>>>>> owslib==0.14 instead and see if geonode works.
>>>>> 2017-09-07 12:18 GMT+02:00 Alessio Fabiani <
>>>>> alessio.fabiani at geo-solutions.it>:
>>>>>> Try to pip uninstall all owslib packages you are on the system
>>>>>> Regards,
>>>>>> Alessio Fabiani
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> 55054  Massarosa
>>>>>> (LU)
>>>>>> Italy
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> On Thu, Sep 7, 2017 at 12:13 PM, Dimitris Karakostis <
>>>>>>> Hello everyone,
>>>>>>> Recently I tried to install a new dev environment using the branch
>>>>>>> 2.7 but I keep getting an error related to OWSLib:
>>>>>>>    "Could not find a version that satisfies the requirement
>>>>>>> OWSLib==0.14-dev"
>>>>>>> I checked the requirements.txt and I see that the OWSLib package is
>>>>>>> commented out.(https://github.com/GeoNod
>>>>>>> e/geonode/blob/2.7.x/requirements.txt)
>>>>>>> I actually uncommented it and rerun the installation but I keep
>>>>>>> getting the same error. I tried to use the master branch as well but there
>>>>>>> is the same.
>>>>>>> Everything works well with 2.6 releases but 2.6 uses a previous
>>>>>>> version of OWSLib as well. Does anyone has similar issues?
>>>>>>> I would like to make some contributions so I guess its better if I
>>>>>>> work on 2.7 or master.
>>>>>>> Thanks
>>>>>>> Cheers
>>>>>>> Dimitris
>>>>>>> _______________________________________________
>>>>>>> geonode-devel mailing list
>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>> Simone
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170907/ab756edd/attachment-0001.html>
More information about the geonode-devel mailing list
