[GeoNode-devel] Issue when installing development environment from 2.7 branch
Dimitris Karakostis karakostis.dimitris at gmail.com
Thu Sep 7 07:24:04 PDT 2017
This actually was it. But there are some new errors I will need to solve.
If it makes sense I can make a pull request with the OWSLib=0.14 both in
setup.py and requirements.txt.
Cheers and thanks again.
On Thu, Sep 7, 2017 at 2:58 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Dimitris, it's because the dependency is in the setup.py
> https://github.com/GeoNode/geonode/blob/2.7.x/setup.py#L92
> so if you installed the 0.14 you can comment that line, test and if it
> works make a PR with the dependency fix both in setup.py and
> requirements.txt ^^ :D
> ty
> 2017-09-07 14:51 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-
> solutions.it>:
>> Thing is, that version it is not yet published on pypi, therefore it
>> should be downloaded from git directly.
>> Quite strange your pip utility does not do it automatically. Do you have
>> the latest pip version? Try with "pip install pip --upgrade" to get the
>> 9.0.1+ one.
>> Otherwise you will need to revert back to older versions and thus
>> manually modify requirements.txt and setup.py
>> Regards,
>> Alessio Fabiani
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>> 55054  Massarosa
>> (LU)
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Thu, Sep 7, 2017 at 2:44 PM, Dimitris Karakostis <
>> karakostis.dimitris at gmail.com> wrote:
>>> Thanks guys,
>>> I uninstalled owslib (also checked for remaining files in
>>> site-packages). It seems everything is deleted properly but still I keep
>>> getting the same error message:
>>>  Could not find a version that satisfies the requirement
>>> OWSLib==0.14-dev (from GeoNode==2.7.dev20170906114728) (from versions:
>>> 0.1.0, 0.2.0, 0.2.1, 0.3, 0.3.1, 0.4.0, 0.5.0, 0.5.1, 0.6.0, 0.6.1, 0.7.0,
>>> 0.7.1, 0.7.2, 0.8.0, 0.8.1, 0.8.2, 0.8.3, 0.8.4, 0.8.5, 0.8.6, 0.8.7,
>>> 0.8.8, 0.8.9, 0.8.10, 0.8.11, 0.8.12, 0.8.13, 0.9.0, 0.9.1, 0.9.2, 0.10.0,
>>> 0.10.1, 0.10.3, 0.11.0, 0.11.1, 0.11.2, 0.12.0, 0.13.0, 0.14.0) No
>>> matching distribution found for OWSLib==0.14-dev (from
>>> I also tried to install OWSLib==0.14 separately. It is installed
>>> successfully but when I try to install the rest of the requirements, I get
>>> the same error.
>>> I will keep trying and write here if I find something.
>>> On Thu, Sep 7, 2017 at 1:24 PM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> Dimitris I see in pypi there's owslib 0.14 try to pip install
>>>> owslib==0.14 instead and see if geonode works.
>>>> 2017-09-07 12:18 GMT+02:00 Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it>:
>>>>> Try to pip uninstall all owslib packages you are on the system
>>>>> Regards,
>>>>> Alessio Fabiani
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> 55054  Massarosa
>>>>> (LU)
>>>>> Italy
>>>>> On Thu, Sep 7, 2017 at 12:13 PM, Dimitris Karakostis <
>>>>>> Hello everyone,
>>>>>> Recently I tried to install a new dev environment using the branch
>>>>>> 2.7 but I keep getting an error related to OWSLib:
>>>>>>    "Could not find a version that satisfies the requirement
>>>>>> OWSLib==0.14-dev"
>>>>>> I checked the requirements.txt and I see that the OWSLib package is
>>>>>> commented out.(https://github.com/GeoNod
>>>>>> e/geonode/blob/2.7.x/requirements.txt)
>>>>>> I actually uncommented it and rerun the installation but I keep
>>>>>> getting the same error. I tried to use the master branch as well but there
>>>>>> is the same.
>>>>>> Everything works well with 2.6 releases but 2.6 uses a previous
>>>>>> version of OWSLib as well. Does anyone has similar issues?
>>>>>> I would like to make some contributions so I guess its better if I
>>>>>> work on 2.7 or master.
>>>>>> Thanks
>>>>>> Cheers
>>>>>> Dimitris
>>>>>> _______________________________________________
>>>>>> geonode-devel mailing list
>>>>>> geonode-devel at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170907/368fb6d2/attachment-0001.html>
More information about the geonode-devel mailing list
