[GeoNode-devel] Geonode 2.8 in Vagrant
Pieter du Plooy pjduplooy.gis at gmail.com
Wed Apr 4 23:27:10 PDT 2018
Hi Toni
So what your saying is that if my router's address range is 192.168.1.xxx,
I could tell vagrant that I want to use 192.168.1.33 (or whatever as last
part), and thats that?
Any case, thanx so much for your help...  O I also saw that you are trying
to get to run geonode on OSX, Any luck with that?
By the way, a Geonode install from PPA, can I use ubuntugis-unstable as the
repo for the gdal, and postgis stuff?
Regards.
Pieter
On Thu, Apr 5, 2018 at 8:01 AM, Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Hey Pieter,
> sure! You could intead just setup your network with Virtual Box GUI and
> add the interface in /etc/network/interfaces. But vagrant can do this for
> you with shown command which is covered here
> https://www.vagrantup.com/docs/networking/private_network.html
> Note that this is for private networking in other words I m using it just
> for testing locally.
> Best, toni
> Am 05.04.2018 um 07:31 schrieb Pieter du Plooy <pjduplooy.gis at gmail.com>:
> Thanx Toni.
> I have always been using vagrant with a standard config, but I do not know
> the private network ip part of the config.  Where does one get that from?
> I've never tinkered a lot with vagrant configs, except to change memory and
> shared folders, and ports, but never private ip.  Would you mind explaining
> a bit further or guiding me?
> Cheers.
> Pieter
> On Wed, Apr 4, 2018 at 9:15 PM, Toni Schönbuchner <
>> Hey Pieter,
>> this should be easy. I´m using a Vagrantfile like this:
>> https://gist.github.com/t-book/7cd26da3b234fa3ddaf881b6c54d7e38
>> then within the same diretory of the Aagrantfile run
>> $ vagrant up
>> $ vagrant ssh
>> $ sudo add-apt-repository ppa:geonode/stable -y
>> $ sudo apt-get update -y
>> $ sudo apt-get install geonode -y
>> $ sudo geonode-updateip 192.168.33.13 # change with your local adress
>> from Vagrantfile
>> Done. Visit your geonode at 192.168.33.13 (or whatever ip you use)
>> If you like to automate the geonode installation (provisioning) you can
>> easily add the steps beginning with
>> to a bootstrap.sh. See vagrant documentation
>> here: https://www.vagrantup.com/intro/getting-started/provisioning.html
>> Cheers,
>> Toni
>> CSGIS
>> Kolonnadenstraße 1
>> <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+1+04109+Leipzig&entry=gmail&source=g>
>> 04109 Leipzig
>> Mobil +49/ (0) 176 6680 3198
>> Tel  +49/ (0) 341 24 04 738
>> Fax  +49/ (0) 341 24 04 73
>> Web http://csgis.de
>> Hinweis gemäß § 33 BDSG
>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>> ausschließlich für den
>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>> diese E-Mail versehentlich
>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>> löschen Sie diese Nachricht
>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>> Vervielfältigung, Veränderung,
>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>> Am 04.04.2018 um 21:00 schrieb geonode-devel-request at lists.osgeo.org:
>>  1. Geonode 2.8 in Vagrant (Pieter du Plooy)
>> Message: 1
>> Date: Wed, 4 Apr 2018 11:07:29 +0200
>> From: Pieter du Plooy <pjduplooy.gis at gmail.com>
>> To: geonode-devel at lists.osgeo.org
>> Subject: [GeoNode-devel] Geonode 2.8 in Vagrant
>> Message-ID:
>> <CADsUavEZ2jJz9YxWa+cnoKmvULNY7tXb3M9A_cxJBLE7XOdPGw at mail.gmail.com>
>> Content-Type: text/plain; charset="utf-8"
>> Hi guys
>> I have used Geonode 2.6.3 successfully in Vagrant using the following
>> instructions:
>> https://training.geonode.geo-solutions.it/002_install_and_ad
>> min/vm_running_vagrant.html
>> (Official Geonode docs is a bit sketchy in this regard).
>> Are there any changes in that particular instructions that you might know
>> of for 2.8?
>> Keep up the good work, and I really hope there will be docker images and
>> Windows installers soon.
>> Pieter
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/
>> 20180404/3b5cb60e/attachment-0001.html>
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180405/e2f060f5/attachment-0001.html>
More information about the geonode-devel mailing list
