[GeoNode-devel] rabbitmq and GeoServer
Paolo Corti
pcorti at gmail.com
Tue Dec 18 07:43:37 PST 2018
Thanks Alessio!
Paolo
On Tue, Dec 18, 2018 at 4:04 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hi Paolo,
> currently, the sync stuff is achieved by the "gs-notifier" plugin. You can
> find the configuration under "$GEOSERVER_DATA_DIR/notifier/notifier.xml"
> I don't think, as far as I know, there exists actually a parameter to
> disable it via configuration (even though it would be quite easy to
> implement it).
> You can try by playing a bit with the notifier.xml file parameter.
> Nevertheless, the most secure way would be to remove temporarily the
> notifier JARs from the "geoserver/WEB-INF/lib" folder.
> [image: image.png]
> Il giorno lun 17 dic 2018 alle ore 23:10 Paolo Corti <pcorti at gmail.com>
> ha scritto:
>> Hello
>> Before submitting this as a new bug, I thought it would be useful to
>> check it here.
>> In our GeoNode instance we have ASYNC_SIGNALS set to False.
>> Even then, I see a lot of logged lines in GeoServer like this - which
>> are slowing down things - for example when a user want to remove a
>> layer:
>> 2018-12-17 22:05:03,888 WARN [common.sender] - Error while trying to
>> initialize RabbitMQ Sender Connecton
>> java.net.ConnectException: Connection refused (Connection refused)
>> at java.net.PlainSocketImpl.socketConnect(Native Method)
>> Which settings should I change in order to disable async communication
>> between Django and GeoServer?
>> Thanks
>> Paolo
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
Paolo Corti
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181218/40d6905e/attachment-0001.html>
More information about the geonode-devel
