[GeoNode-devel] rabbitmq and GeoServer
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Tue Dec 18 01:04:28 PST 2018
Hi Paolo,
currently, the sync stuff is achieved by the "gs-notifier" plugin. You can
find the configuration under "$GEOSERVER_DATA_DIR/notifier/notifier.xml"
I don't think, as far as I know, there exists actually a parameter to
disable it via configuration (even though it would be quite easy to
implement it).
You can try by playing a bit with the notifier.xml file parameter.
Nevertheless, the most secure way would be to remove temporarily the
notifier JARs from the "geoserver/WEB-INF/lib" folder.
[image: image.png]
Il giorno lun 17 dic 2018 alle ore 23:10 Paolo Corti <pcorti at gmail.com> ha
scritto:
> Hello
> Before submitting this as a new bug, I thought it would be useful to
> check it here.
> In our GeoNode instance we have ASYNC_SIGNALS set to False.
> Even then, I see a lot of logged lines in GeoServer like this - which
> are slowing down things - for example when a user want to remove a
> layer:
> 2018-12-17 22:05:03,888 WARN [common.sender] - Error while trying to
> initialize RabbitMQ Sender Connecton
> java.net.ConnectException: Connection refused (Connection refused)
> at java.net.PlainSocketImpl.socketConnect(Native Method)
> Which settings should I change in order to disable async communication
> between Django and GeoServer?
> Thanks
> Paolo
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181218/7f632e17/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181218/7f632e17/attachment.png>
More information about the geonode-devel
