[GeoNode-devel] Custom geonode project installation
Dimitris Kar dkarakostis at gmail.com
Wed Dec 19 08:49:56 PST 2018
Thanks Toni,
So to understand, if I want to have my own geonode-project, I don't need to
go through the process of installing 'geonode core'. I can directly install
the geonode-project?
But if I understand correctly the training instructions (
http://geonode.org/dev-workshop/#/3/2) I need to follow the below steps
after I have installed the 'geonode core project':
1. Make sure to run it just outside the geonode folder as we will keep them
completely separate: django-admin.py startproject my_geonode --template=
https://github.com/GeoNode/geonode-project/archive/master.zip -e
py,rst,json,yml,ini,env,sample -n Dockerfile my_geonode
2. *workon geonode* and
3. execute: pip install -e my_geonode
4.  DJANGO_SETTINGS_MODULE=my_geonode.local_settings paver start
What eventually need is to have two different folders. One with the geonode
core project, which I want modify and the other one with my_geonode
project, in which I will apply changes.
On Wed, Dec 19, 2018 at 5:27 PM Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Hi Dimitris,
> it sounds you´re a bit puzzled between 'geonode core‘ and geonode-project.
> To understand better see whats happening with geonode-project:
> It installs `geonode core` as dependency:
> https://github.com/GeoNode/geonode-project/blob/master/requirements.txt#L2
> further loads/overwrites it´s settings:
> https://github.com/GeoNode/geonode-project/blob/master/project_name/settings.py#L30
> Doing so we can overwrite things like templates etc. in Geonode-Project
> without touching
> core files.
> As a rule of thumb, if you´d like to commit changes to geonode core,
> create a fork of the upstream
> repository, do your changes and create a PR.
> I think in your case – as you´d like to modify *your* specific version –
> start by creating a geonode
> project as described here (and ignore the first 'geonode core' dev setup):
> https://github.com/GeoNode/geonode-project#create-a-custom-project
> I hope I did not misunderstood your question.
> Happy geonod’ ing.
> – Toni
> CSGIS
> Kolonnadenstraße 1
> 04109 Leipzig
> Mobil +49/ (0) 176 6680 3198
> Tel  +49/ (0) 341 24 04 738
> Fax  +49/ (0) 341 24 04 73
> Web http://csgis.de
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
> ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> Message: 1
> Date: Wed, 19 Dec 2018 16:57:16 +0100
> From: Dimitris Kar <dkarakostis at gmail.com>
> To: geonode-devel <geonode-devel at lists.osgeo.org>
> Subject: [GeoNode-devel] Custom geonode project installation
> Message-ID:
> <CAH4UFc99H4OuAxKUc+FhFZ=13gSJZDdMnH7Lj1=ec49Qg+6sgA at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hello all,
> I am trying following the instructions from this workshop (
> http://geonode.org/dev-workshop/#/2) in order to install GeoNode and a
> GeoNode project. I have installed GeoNode in dev mode using a python
> virtualenv + django development server method.
> Then I follow the instructions in order to create a geonode-project as
> following:
>   1. cd ./geonode
>   2. django-admin.py startproject wfp_geonode --template=
>   py,rst,json,yml,ini,env,sample -n Dockerfile wfp_geonode  (I executed
>   this command without includong: -n Dockerfile wfp_geonode)
>   3. workon geonode
>   4. cd wfp_geonode
>   5. pip install -e wfp_geonode
>   6. cd ../geonode
>   7. DJANGO_SETTINGS_MODULE=wfp_geonode.local_settings paver start
> But when I actually run the command, I get the below command. If I am not
> wrong, I remember, that I can not use geonode-project aside with a geonode
> dev installation but this is not quite clear in the above workshop
> presentation (see above link).
> Did anyone had similar issues? Should I install a geonode for production
> and use the geonode-project then?
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181219/a558ed38/attachment-0001.html>
More information about the geonode-devel mailing list
