[GeoNode-devel] geonode-devel Digest, Vol 37, Issue 21
Simone Dalmasso
simone.dalmasso at gmail.com
Wed Feb 14 06:51:50 PST 2018
ok thanks Tom! definitely we have to fix this as will affect all pip
installations.
2018-02-14 15:46 GMT+01:00 Thomas Gertin <tgertin at vt.edu>:
> sorry I mis-typed. What I meant to say is that in the django-polymorphic
> GitHub repo <https://github.com/django-polymorphic/django-polymorphic>,
> it says for *older Django versions than 1.11, install
> django-polymorphic==1.3.*
> I think that right now the 'django-polymorphic>=0.9.2' requirement
> installs a version of django-polymorphic newer than version 1.3, which
> requires Django version 1.11 or higher, which we don't want.
> On Wed, Feb 14, 2018 at 8:00 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Dear Tom,
>> GeoNode 2.6 runs with Django 1.8 so we need to stay with it. I'm
>> wondering why the 1.11 is installed.
>> Silvia and others also ran in the issue with slugify lately so we need to
>> investigate what happens there. We haven0t changes the 2.6.x as far as I
>> know so something must have changed in the dependencies.
>> 2018-02-14 12:54 GMT+01:00 Thomas Gertin <tgertin at vt.edu>:
>>> I ran into the same issue you had today SILVIA.
>>> I noticed that for for the pypy GeoNode 2.6.1 package (
>>> https://pypi.python.org/pypi/GeoNode/2.6.1), the requirements.txt file
>>> lists django-polymorphic as
>>> However, as stated in the django-polymorphic GitHub repo,
>>> django-polymorphic==1.3 should be installed for Django 1.11.
>>> Can you try uninstalling django-polymorphic, and installing version 1.3?
>>> To all,
>>> Can we put 'django-polymorphic==1.3' in the requirements.txt for GeoNode
>>> 2.6.1?
>>> I am having problems now with awesome-slugify installing correctly, but
>>> I need think I need to look into this further.
>>> Thanks,
>>> Tom G.
>>> > On Feb 13, 2018, at 3:00 PM, geonode-devel-request at lists.osgeo.org
>>> wrote:
>>> > Send geonode-devel mailing list submissions to
>>> > geonode-devel at lists.osgeo.org
>>> > To subscribe or unsubscribe via the World Wide Web, visit
>>> > https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> > or, via email, send a message with subject or body 'help' to
>>> > You can reach the person managing the list at
>>> > geonode-devel-owner at lists.osgeo.org
>>> > When replying, please edit your Subject line so it is more specific
>>> > than "Re: Contents of geonode-devel digest..."
>>> > Today's Topics:
>>> > 1. pkg_resources.VersionConflict when python manage.py migrate
>>> > (SILVIA GAMERO)
>>> > 2. Re: pkg_resources.VersionConflict when python manage.py
>>> > migrate (Simone Dalmasso)
>>> > Message: 1
>>> > Date: Mon, 12 Feb 2018 16:09:15 -0600
>>> > From: SILVIA GAMERO <gamerinsky at gmail.com>
>>> > To: geonode-devel at lists.osgeo.org
>>> > Subject: [GeoNode-devel] pkg_resources.VersionConflict when python
>>> > manage.py migrate
>>> > Message-ID:
>>> > <CAKjeEPWFkjQb9_EaOqEMCcdo+19tcZCMJymSQPcEHRdV7SiYZA at mail.g
>>> mail.com>
>>> > Content-Type: text/plain; charset="utf-8"
>>> > I have problems with geonode2.6x on Centos7, when migrating the data
>>> from
>>> > python manage.py migrate or try to start geonode ..
>>> > Traceback (most recent call last):
>>> > File "/usr/lib/python2.7/site-packages/django/utils/autoreload.py",
>>> line
>>> > 229, in wrapper
>>> > fn(*args, **kwargs)
>>> > File
>>> > "/usr/lib/python2.7/site-packages/django/core/management/com
>>> mands/runserver.py",
>>> > line 107, in inner_run
>>> > autoreload.raise_last_exception()
>>> line
>>> > 252, in raise_last_exception
>>> > six.reraise(*_exception)
>>> line
>>> > 229, in wrapper
>>> > fn(*args, **kwargs)
>>> > File "/usr/lib/python2.7/site-packages/django/__init__.py", line 18,
>>> in
>>> > setup
>>> > apps.populate(settings.INSTALLED_APPS)
>>> > File "/usr/lib/python2.7/site-packages/django/apps/registry.py",
>>> line 85,
>>> > in populate
>>> > app_config = AppConfig.create(entry)
>>> > File "/usr/lib/python2.7/site-packages/django/apps/config.py", line
>>> 86,
>>> > in create
>>> > module = import_module(entry)
>>> > File "/usr/lib64/python2.7/importlib/__init__.py", line 37, in
>>> > import_module
>>> > __import__(name)
>>> > File "/usr/lib/python2.7/site-packages/polymorphic/__init__.py",
>>> line 13,
>>> > in <module>
>>> > __version__ = pkg_resources.require("django-
>>> polymorphic")[0].version
>>> > File "/usr/lib/python2.7/site-packages/pkg_resources.py", line 728,
>>> in
>>> > require
>>> > needed = self.resolve(parse_requirements(requirements))
>>> > File "/usr/lib/python2.7/site-packages/pkg_resources.py", line 630,
>>> in
>>> > resolve
>>> > raise VersionConflict(dist,req) # XXX put more info here
>>> > pkg_resources.VersionConflict: (Django 1.8.18
>>> > (/usr/lib/python2.7/site-packages), Requirement.parse('Django>=1.11'))
>>> > I followed the steps of the installation guide, although I commented
>>> that I
>>> > have not done the process that explain for the development mode, but
>>> > starting from the installation of postgres, tomcat, geoserver and
>>> finally
>>> > geonode.
>>> > With these same steps I had done a previous installation but I had
>>> problems
>>> > wanting to upload shapes to geonode or geoserver so I had to reinstall
>>> > everything again.
>>> > The version of Django that I am currently observing is the 1.8.18
>>> > I would greatly appreciate the help of someone who has already been
>>> able to
>>> > do the installation correctly.
>>> > -------------- next part --------------
>>> > An HTML attachment was scrubbed...
>>> > URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/
>>> 20180212/9f36e2e5/attachment-0001.html>
>>> > Message: 2
>>> > Date: Tue, 13 Feb 2018 07:20:16 +0100
>>> > From: Simone Dalmasso <simone.dalmasso at gmail.com>
>>> > To: SILVIA GAMERO <gamerinsky at gmail.com>
>>> > Cc: geonode-devel <geonode-devel at lists.osgeo.org>
>>> > Subject: Re: [GeoNode-devel] pkg_resources.VersionConflict when python
>>> > manage.py migrate
>>> > Message-ID:
>>> > <CAAHAC+cxy+tG9v3nSS9zLPGPnJhoo7y6HjvQ1NSE6LCbJT4OjQ at mail.g
>>> mail.com>
>>> > Hi, your django version is correct but looks like other libraries are
>>> not,
>>> > like polymorphic. I suggest to run pip install -r requirements.txt
>>> again.
>>> > 2018-02-12 23:09 GMT+01:00 SILVIA GAMERO <gamerinsky at gmail.com>:
>>> from
>>> >> line 229, in wrapper
>>> >> fn(*args, **kwargs)
>>> >> File "/usr/lib/python2.7/site-packages/django/core/
>>> >> management/commands/runserver.py", line 107, in inner_run
>>> >> line 252, in raise_last_exception
>>> >> fn(*args, **kwargs)
>>> 18, in
>>> >> setup
>>> line
>>> >> 85, in populate
>>> 86,
>>> >> in create
>>> >> import_module
>>> >> __import__(name)
>>> line
>>> >> 13, in <module>
>>> in
>>> >> require
>>> in
>>> >> resolve
>>> that
>>> >> I have not done the process that explain for the development mode, but
>>> finally
>>> >> geonode.
>>> >> problems wanting to upload shapes to geonode or geoserver so I had to
>>> >> reinstall everything again.
>>> able
>>> >> to do the installation correctly.
>>> >> _______________________________________________
>>> > Simone
>>> 20180213/365c2a0e/attachment-0001.html>
>>> > Subject: Digest Footer
>>> > End of geonode-devel Digest, Vol 37, Issue 21
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180214/435e6a50/attachment-0001.html>
More information about the geonode-devel
