[GeoNode-devel] geonode-devel Digest, Vol 37, Issue 21
Thomas Gertin
tgertin at vt.edu
Wed Feb 14 14:43:22 PST 2018
Simone,
with the awesome-slugify package there was an issue(
https://github.com/dimka665/awesome-slugify/pull/22) in its GitHub repo
that was supposed to fix the ImportError. However in the awesome-slugify
PyPy package I don't see the fix implemented. What I did for myself was pip
uninstall awesome-slugify then I installed awesome-slugify from its GItHub
repo (The Github repo has the fix). I used the command: pip install
https://github.com/dimka665/awesome-slugify/archive/master.zip
This worked for me.
Thanks,
-Tom
On Wed, Feb 14, 2018 at 9:51 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> ok thanks Tom! definitely we have to fix this as will affect all pip
> installations.
> 2018-02-14 15:46 GMT+01:00 Thomas Gertin <tgertin at vt.edu>:
>> sorry I mis-typed. What I meant to say is that in the django-polymorphic
>> GitHub repo <https://github.com/django-polymorphic/django-polymorphic>,
>> it says for *older Django versions than 1.11, install
>> django-polymorphic==1.3.*
>> I think that right now the 'django-polymorphic>=0.9.2' requirement
>> installs a version of django-polymorphic newer than version 1.3, which
>> requires Django version 1.11 or higher, which we don't want.
>> On Wed, Feb 14, 2018 at 8:00 AM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Dear Tom,
>>> GeoNode 2.6 runs with Django 1.8 so we need to stay with it. I'm
>>> wondering why the 1.11 is installed.
>>> Silvia and others also ran in the issue with slugify lately so we need
>>> to investigate what happens there. We haven0t changes the 2.6.x as far as I
>>> know so something must have changed in the dependencies.
>>> 2018-02-14 12:54 GMT+01:00 Thomas Gertin <tgertin at vt.edu>:
>>>> I ran into the same issue you had today SILVIA.
>>>> I noticed that for for the pypy GeoNode 2.6.1 package (
>>>> https://pypi.python.org/pypi/GeoNode/2.6.1), the requirements.txt file
>>>> lists django-polymorphic as
>>>> However, as stated in the django-polymorphic GitHub repo,
>>>> django-polymorphic==1.3 should be installed for Django 1.11.
>>>> Can you try uninstalling django-polymorphic, and installing version 1.3?
>>>> To all,
>>>> Can we put 'django-polymorphic==1.3' in the requirements.txt for
>>>> GeoNode 2.6.1?
>>>> I am having problems now with awesome-slugify installing correctly, but
>>>> I need think I need to look into this further.
>>>> Thanks,
>>>> Tom G.
>>>> > On Feb 13, 2018, at 3:00 PM, geonode-devel-request at lists.osgeo.org
>>>> wrote:
>>>> > Send geonode-devel mailing list submissions to
>>>> > geonode-devel at lists.osgeo.org
>>>> > To subscribe or unsubscribe via the World Wide Web, visit
>>>> > https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>> > or, via email, send a message with subject or body 'help' to
>>>> > You can reach the person managing the list at
>>>> > geonode-devel-owner at lists.osgeo.org
>>>> > When replying, please edit your Subject line so it is more specific
>>>> > than "Re: Contents of geonode-devel digest..."
>>>> > Today's Topics:
>>>> > 1. pkg_resources.VersionConflict when python manage.py migrate
>>>> > (SILVIA GAMERO)
>>>> > 2. Re: pkg_resources.VersionConflict when python manage.py
>>>> > migrate (Simone Dalmasso)
>>>> > Message: 1
>>>> > Date: Mon, 12 Feb 2018 16:09:15 -0600
>>>> > From: SILVIA GAMERO <gamerinsky at gmail.com>
>>>> > To: geonode-devel at lists.osgeo.org
>>>> > Subject: [GeoNode-devel] pkg_resources.VersionConflict when python
>>>> > manage.py migrate
>>>> > Message-ID:
>>>> > <CAKjeEPWFkjQb9_EaOqEMCcdo+19tcZCMJymSQPcEHRdV7SiYZA at mail.g
>>>> mail.com>
>>>> > Content-Type: text/plain; charset="utf-8"
>>>> > I have problems with geonode2.6x on Centos7, when migrating the data
>>>> from
>>>> > python manage.py migrate or try to start geonode ..
>>>> > Traceback (most recent call last):
>>>> > File "/usr/lib/python2.7/site-packages/django/utils/autoreload.py",
>>>> line
>>>> > 229, in wrapper
>>>> > fn(*args, **kwargs)
>>>> > File
>>>> > "/usr/lib/python2.7/site-packages/django/core/management/com
>>>> mands/runserver.py",
>>>> > line 107, in inner_run
>>>> > autoreload.raise_last_exception()
>>>> line
>>>> > 252, in raise_last_exception
>>>> > six.reraise(*_exception)
>>>> line
>>>> > 229, in wrapper
>>>> > fn(*args, **kwargs)
>>>> > File "/usr/lib/python2.7/site-packages/django/__init__.py", line
>>>> 18, in
>>>> > setup
>>>> > apps.populate(settings.INSTALLED_APPS)
>>>> > File "/usr/lib/python2.7/site-packages/django/apps/registry.py",
>>>> line 85,
>>>> > in populate
>>>> > app_config = AppConfig.create(entry)
>>>> > File "/usr/lib/python2.7/site-packages/django/apps/config.py", line
>>>> 86,
>>>> > in create
>>>> > module = import_module(entry)
>>>> > File "/usr/lib64/python2.7/importlib/__init__.py", line 37, in
>>>> > import_module
>>>> > __import__(name)
>>>> > File "/usr/lib/python2.7/site-packages/polymorphic/__init__.py",
>>>> line 13,
>>>> > in <module>
>>>> > __version__ = pkg_resources.require("django-
>>>> polymorphic")[0].version
>>>> > File "/usr/lib/python2.7/site-packages/pkg_resources.py", line 728,
>>>> in
>>>> > require
>>>> > needed = self.resolve(parse_requirements(requirements))
>>>> > File "/usr/lib/python2.7/site-packages/pkg_resources.py", line 630,
>>>> in
>>>> > resolve
>>>> > raise VersionConflict(dist,req) # XXX put more info here
>>>> > pkg_resources.VersionConflict: (Django 1.8.18
>>>> > (/usr/lib/python2.7/site-packages), Requirement.parse('Django>=1.1
>>>> 1'))
>>>> > I followed the steps of the installation guide, although I commented
>>>> that I
>>>> > have not done the process that explain for the development mode, but
>>>> > starting from the installation of postgres, tomcat, geoserver and
>>>> finally
>>>> > geonode.
>>>> > With these same steps I had done a previous installation but I had
>>>> problems
>>>> > wanting to upload shapes to geonode or geoserver so I had to reinstall
>>>> > everything again.
>>>> > The version of Django that I am currently observing is the 1.8.18
>>>> > I would greatly appreciate the help of someone who has already been
>>>> able to
>>>> > do the installation correctly.
>>>> > -------------- next part --------------
>>>> > An HTML attachment was scrubbed...
>>>> > URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/
>>>> 20180212/9f36e2e5/attachment-0001.html>
>>>> > Message: 2
>>>> > Date: Tue, 13 Feb 2018 07:20:16 +0100
>>>> > From: Simone Dalmasso <simone.dalmasso at gmail.com>
>>>> > To: SILVIA GAMERO <gamerinsky at gmail.com>
>>>> > Cc: geonode-devel <geonode-devel at lists.osgeo.org>
>>>> > Subject: Re: [GeoNode-devel] pkg_resources.VersionConflict when python
>>>> > manage.py migrate
>>>> > Message-ID:
>>>> > <CAAHAC+cxy+tG9v3nSS9zLPGPnJhoo7y6HjvQ1NSE6LCbJT4OjQ at mail.g
>>>> mail.com>
>>>> > Hi, your django version is correct but looks like other libraries are
>>>> not,
>>>> > like polymorphic. I suggest to run pip install -r requirements.txt
>>>> again.
>>>> > 2018-02-12 23:09 GMT+01:00 SILVIA GAMERO <gamerinsky at gmail.com>:
>>>> from
>>>> >> line 229, in wrapper
>>>> >> fn(*args, **kwargs)
>>>> >> File "/usr/lib/python2.7/site-packages/django/core/
>>>> >> management/commands/runserver.py", line 107, in inner_run
>>>> >> line 252, in raise_last_exception
>>>> >> fn(*args, **kwargs)
>>>> 18, in
>>>> >> setup
>>>> line
>>>> >> 85, in populate
>>>> line 86,
>>>> >> in create
>>>> >> import_module
>>>> >> __import__(name)
>>>> line
>>>> >> 13, in <module>
>>>> 728, in
>>>> >> require
>>>> 630, in
>>>> >> resolve
>>>> >> Requirement.parse('Django>=1.11'))
>>>> that
>>>> >> I have not done the process that explain for the development mode,
>>>> but
>>>> finally
>>>> >> geonode.
>>>> >> problems wanting to upload shapes to geonode or geoserver so I had to
>>>> >> reinstall everything again.
>>>> able
>>>> >> to do the installation correctly.
>>>> >> _______________________________________________
>>>> > Simone
>>>> 20180213/365c2a0e/attachment-0001.html>
>>>> > Subject: Digest Footer
>>>> > End of geonode-devel Digest, Vol 37, Issue 21
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180214/22268f3f/attachment-0001.html>
More information about the geonode-devel
