[GeoNode-devel] CSV upload with column named "location" fails (new issue #3557)
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Jan 11 02:33:57 PST 2018
CSV upload, lon/lat and crs recognition other than time-dimension, has been
improved and fixed with this PR
https://github.com/GeoNode/geonode/pull/3489
(still to be merged) but only on GeoNode 2.9.x
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
2018-01-11 6:46 GMT+01:00 Jonathan Doig <j.doig at unsw.edu.au>:
> Hi all
> New bug tested on Geonode 2.4: in layers/upload, trying to upload a CSV
> file with a column named 'location' either fails with the message 'BAD
> REQUEST' in the page, or appears to hang and never finish uploading.
> E.g. upload a CSV file containing just 1 record:
> location,longitude,latitude
> Atherton,145.48586,-17.26608
> Geoserver.log explains that PostgreSQL is failing to create another
> 'location' column.
> One option would be to check for that column name and gracefully exit with
> a message like:
> “The attribute name ‘location’ is reserved. Please rename this attribute
> in your data before uploading again.”
> Raised a new Geonode issue #3557
> <https://github.com/GeoNode/geonode/issues/3557>.
> Regards
> Jonathan
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180111/d1087774/attachment-0001.html>
More information about the geonode-devel
