[GeoNode-devel] CSV upload with column named "location" fails (new issue #3557)
Jonathan Doig j.doig at unsw.edu.au
Thu Jan 11 04:19:13 PST 2018
Great – GNIP looks impressive!
Regards
Jonathan
From: Alessio Fabiani [mailto:alessio.fabiani at geo-solutions.it]
Sent: Thursday, 11 January 2018 9:34 PM
To: Jonathan Doig <j.doig at unsw.edu.au>
Cc: geonode-devel <geonode-devel at lists.osgeo.org>
Subject: Re: [GeoNode-devel] CSV upload with column named "location" fails (new issue #3557)
CSV upload, lon/lat and crs recognition other than time-dimension, has been improved and fixed with this PR
https://github.com/GeoNode/geonode/pull/3489
(still to be merged) but only on GeoNode 2.9.x
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
2018-01-11 6:46 GMT+01:00 Jonathan Doig <j.doig at unsw.edu.au<mailto:j.doig at unsw.edu.au>>:
Hi all
New bug tested on Geonode 2.4: in layers/upload, trying to upload a CSV file with a column named 'location' either fails with the message 'BAD REQUEST' in the page, or appears to hang and never finish uploading.
E.g. upload a CSV file containing just 1 record:
location,longitude,latitude
Atherton,145.48586,-17.26608
Geoserver.log explains that PostgreSQL is failing to create another 'location' column.
One option would be to check for that column name and gracefully exit with a message like:
“The attribute name ‘location’ is reserved. Please rename this attribute in your data before uploading again.”
Raised a new Geonode issue #3557<https://github.com/GeoNode/geonode/issues/3557>.
Regards
Jonathan
geonode-devel mailing list
geonode-devel at lists.osgeo.org<mailto:geonode-devel at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180111/c4850e9e/attachment.html>
More information about the geonode-devel mailing list
