[GeoNode-devel] Custom map search via GeoNode
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Jan 12 01:11:58 PST 2018
Hi Varun,
not that easy to reply to your question quickly. Basically all spatial data
is handled by a backend server called GeoServer and exposed through
Opengeospatial Web Protocols.
So, in principle yes, is possible to do what you are asking, but, at least
with the default gis client integrated into GeoNode, there's no, let's say,
"user friendly" functionality to achieve that.
Long story short, most of the things you are asking should be probably
implemented on client-side, which means handling with Javascript and CSS.
There are other pluggable GIS clients that can be plugged into GeoNode
written using REACT. Also others around can be "relatively" easily
integrated into GeoNode. As an instance I know Boundless implementation is
using MapLoom (if I'm not wrong).
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
2017-12-25 20:37 GMT+01:00 varun shah <varun.shah196 at gmail.com>:
> Hi!
> I want to build a web application which supports map based search, and I
> was wondering if I can do it via GeoNode.
> I have a custom shape file, which I wish to upload and display as a map,
> along with the feature information. This can be readily achieved via
> GeoNode.
> However, I also want users to be able to select a particular area of the
> map and then display only the features in that area, or take input
> coordinates and show features in the specified area, and several such small
> changes.
> I could not find documentation on how to customise the GeoNode application
> for these. Specifically, I want to know how can I take the coordinates
> selected on map in my program as input; and how can I display only a small
> subset of features in the map?
> Is this achievable via GeoNode? If yes, a link to reference/documentation
> would be a great help.
> Thank you!
> Regards,
> Varun Shah
> Regards,
> Varun Shah
> (M) +91 9712820311 <+91%2097128%2020311>
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180112/fc2322f8/attachment.html>
More information about the geonode-devel mailing list
