[GeoNode-devel] Move to Release 2.8
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Jan 22 02:04:34 PST 2018
Hi Dave,
thank you very much for your help and feedbacks.
>From what you reported it seems that the installation process went well it
is mostly a configuration issue.
In particular it looks like on GeoNode Admin > Django OAuth Toolkit >
Applications (http://54.206.23.196/admin/oauth2_provider/application/) the
"GeoServer" Application is missing the correct "REDIRECT_URI"s
[image: Immagine incorporata 1]
In your specific use case you will need to add to the above configured on
you GeoNode instance, the ones specified on GeoServer oauth2 configuration.
- Login to GeoServer Admin GUI with admin credentials (by default admin /
geoserver)
- Go to Security > Authentication > geonode-oauth2 and make sure the
"Redirect URI" is listed on GeoNode App
[image: Immagine incorporata 2]
Also, if the "geonode-updateip" command went well, you should see here all
hosts pointing to your public IP. Long story short both GeoServerver and
GeoNode should report in your case "http://54.206.23.196/geoserver/" as
Redirect URI.
*Summary*
>From what you reported - and if you can confirm the steps above fix your
issue - it looks to me that the problem is on updateip management command
more than on the installation process.
In any case this must be improved and fixed. I will double check and do
more tests on this.
*Notice*
On a PUBLIC instance you *must* perform other manual steps before exposing
it to the web:
1. Update the GeoServer by changing:
Internal "admin" password - this change must be reflected on GeoNode
local_settings also
Internal "master" password
2. Update OAuth2 Client-ID and Client-Secret tokens
Update GeoNode GeoServer Oauth2 App
Update GeoServer "geonode-oauth2" service accordingly
3. Change the GeoNode default "admin" password
*warning: *"admin" user must exists. Do not remove it, just change its
passowrd
*note:* "admin" user *is different* from internal GeoServer admin one
4- make sure the DB does not use simple passwords and users
5- double check the filesystem permissions and secure static / upload
folders
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
2018-01-22 8:16 GMT+01:00 Dave Kennewell <davekennewell at gmail.com>:
> Hi Alessio,
> Thanks so much for putting the energy into this. I made two tries to get
> it working:
> ___________________________________________________
> *First attempt*
> I installed on a fresh 16.04 Ubuntu server EC2 instance on AWS. The
> package install worked fine (although took +30mins to download the packages
> - I guess this is normal for a new launchpad repo).
> However the command
> IP_ADDRESS=$(ip route get 8.8.8.8 | awk '{print $NF; exit}')
> will pick up the PRIVATE IP address on an Amazon instance, which leads to
> "400 Bad Request" errors when trying to access Geonode through the
> internet.
> So I run the command instead with the PUBLIC IP:
> sudo geonode-updateip 54.206.48.105
> and now it throws and error while "Inspecting the available layers in
> GeoServer" (apologies, I didn't record the exact error before I terminated
> the machine & realised that would have been useful!)
> But, the django part of geonode is accessible now, just not the geoserver
> parts. I don't think it was valuable to delve into custom config to get a
> release working, so I tried again from scratch...
> ____________________________________________________
> *Second attempt*
> I terminated the first machine and started again but this time I just
> updated to the PUBLIC IP:
> sudo geonode-updateip 54.206.23.196
> Now there's no errors, and both django and geoserver parts of the app are
> at least working. I can upload both raster and vector layers, and they will
> display in the map preview.
> However a few quick tests show the following bugs:
> 1. Once I'm logged in to the django app, if I try and log in to the
> geoserver index page using the geonode button, I get the following error in
> my browser:
>> Error: invalid_request
>> Mismatching redirect URI.
> 2. The vector layer is displayed in the map preview map (
> http://54.206.23.196/layers/geonode:model_boundary), but I get pink tiles
> if I try and "create a map" and view in geoexplorer. (
> http://54.206.23.196/maps/new?layer=geonode:model_boundary)
> I'll leave this instance up & running for a couple of days if you wish to
> investigate. I can send you superuser details direct if it will help debug,
> let me know.
> Thanks again
> Dave
> On 19 January 2018 at 17:20, Alessio Fabiani-2 [via OSGeo.org] <
> ml+s1560n5350525h90 at n6.nabble.com> wrote:
>> Release process ongoing.
>> For whom willing to try geonode 2.8.0, on a clean Ubuntu 16.04 instance
>> just run the following commands
>> sudo add-apt-repository ppa:geonode/testing
>> sudo apt update
>> sudo apt install geonode
>> geonode createsuperuser
>> sudo geonode-updateip $IP_ADDRESS
>> sudo service apache2 restart
>> This is still under testing, so 1. do not try this on production servers
>> - or on server where you have installations you don't want to break ; 2. it
>> is possible that something goes wrong - in this case please report to me
>> Regards,
>> Alessio Fabiani
>> http://goo.gl/it488V for more information.
>> @alfa7691
>> GeoSolutions S.A.S.
>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>> 55054 Massarosa
>> (LU)
>> Italy
>> phone: +39 0584 962313 <0584%20962313>
>> fax: +39 0584 1660272 <0584%20166%200272>
>> mob: +39 331 6233686 <331%20623%203686>
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> completeness of sent messages and accepts no responsibility for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> 2017-12-23 11:29 GMT+01:00 Paolo Corti <[hidden email]
>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=0>>:
>>> +1!
>>> of course
>>> Paolo
>>> On Fri, Dec 22, 2017 at 12:47 AM, Francesco Bartoli
>>> <[hidden email] <http:///user/SendEmail.jtp?type=node&node=5350525&i=1>>
>>> wrote:
>>> > Hi Rizky,
>>> > yes you should backport it to 2.7.x which will become 2.8.0 then.
>>> > Ciao
>>> > Il giorno 21/dic/2017, alle ore 22:49, Rizky Maulana Nugraha
>>> > <[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=2>> ha scritto:
>>> > +1
>>> > Can I also know how are you going to release 2.8? Is it coming from
>>> 2.7.x
>>> > branch? I would like to include qgis-server backend if possible, but
>>> that
>>> > depends on how much effort that would be. At the moment, only master
>>> branch
>>> > have qgis-server backend.
>>> > Software Developer
>>> > Kartoza.com
>>> > On Dec 22, 2017 02:15, "Tom Kralidis" <[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=3>> wrote:
>>> >> +1
>>> >> ..Tom
>>> >> Sent from my iPhone
>>> >> On Dec 21, 2017, at 14:13, Simone Dalmasso <[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=4>>
>>> >> wrote:
>>> >> +1!
>>> >> 2017-12-21 19:52 GMT+01:00 Jeremiah Cooper <[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=5>>:
>>> >>> +1.
>>> >>> Thanks.
>>> >>> Jeremiah Cooper
>>> >>> On Thu, Dec 21, 2017 at 1:06 PM, Alessio Fabiani
>>> >>> <[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=6>> wrote:
>>> >>>> +1
>>> >>>> Regards,
>>> >>>> Alessio Fabiani
>>> >>>> @alfa7691
>>> >>>> GeoSolutions S.A.S.
>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+%0D+%3E%3E%3E%3E+55054%C2%A0+Massarosa&entry=gmail&source=g>
>>> >>>> 55054 Massarosa
>>> (LU)
>>> >>>> Italy
>>> >>>> phone: <a href="tel:%2B39%200584%20962313" value="+390584962313
>>> <0584%20962313>">+39 0584 962313 <0584%20962313>
>>> >>>> fax: <a href="tel:%2B39%200584%201660272" value="+3905841660272
>>> <0584%20166%200272>">+39 0584 1660272 <0584%20166%200272>
>>> >>>> mob: <a href="tel:%2B39%20331%206233686" value="+393316233686
>>> <331%20623%203686>">+39 331 6233686 <331%20623%203686>
>>> e/o
>>> riservate. Il loro
>>> per le
>>> messaggio
>>> >>>> senza esserne il destinatario, Vi preghiamo cortesemente di darcene
>>> notizia
>>> >>>> via e-mail e di procedere alla distruzione del messaggio stesso,
>>> divulgarlo
>>> utilizzarlo per
>>> >>>> finalità diverse, costituisce comportamento contrario ai principi
>>> dettati
>>> solely
>>> confidential
>>> Protection
>>> reproduction,
>>> partial, is
>>> sender does
>>> or
>>> changes
>>> result of
>>> >>>> On 21 dicembre 2017 17:43, Francesco Bartoli <[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=7>>
>>> >>>> wrote:
>>> >>>>> Hi devs,
>>> >>>>> as 2.7.x became quite stable we should be ready to move to
>>> releasing
>>> >>>>> 2.8.0 as new stable version. Any feedback or concern?
>>> >>>>> At the moment we don’t have a release manager but Alessio, Angelos
>>> and
>>> >>>>> me can volunteer. However it’s likely we need some guidance to the
>>> overall
>>> >>>>> procedure.
>>> >>>>> Thanks and Merry Christmas to all of you
>>> >>>>> Francesco
>>> >>>>> geonode-devel mailing list
>>> >>>>> [hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=8>
>>> >>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> >>>> [hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=9>
>>> >>> [hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=10>
>>> >> Simone
>>> >> [hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=11>
>>> >> [hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=12>
>>> > [hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=13>
>>> > [hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=14>
>>> Paolo Corti
>>> Geospatial software developer
>>> web: http://www.paolocorti.net
>>> twitter: @capooti
>>> skype: capooti
>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5350525&i=15>
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5350525&i=16>
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1560.x6.nabble.com/Move-to-Release-2-8-
>> tp5347506p5350525.html
>> To unsubscribe from GeoNode devel, click here
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5185388&code=ZGF2ZWtlbm5ld2VsbEBnbWFpbC5jb218NTE4NTM4OHwtOTI1NjEyMTk0>
>> NAML
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> geonode-devel at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180122/b12e0dcc/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180122/b12e0dcc/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180122/b12e0dcc/attachment-0003.png>
More information about the geonode-devel
