[GeoNode-devel] Move to Release 2.8
    Dave Kennewell
    davekennewell at gmail.com
    Mon Jan 22 21:29:13 PST 2018
Hi Alessio,
Yes, I agree it's more a configuration issue than an install issue. The
package install worked fine.
When I login to the geoserver GUI, the Redirect URI is listed with an
additional slash after geoserver:
[image: Inline images 1]
And in
Django admin -> Django OAuth Toolkit -> Applications -> GeoServer
it lists the Redirect uris without the "/index.html" appended:
[image: Inline images 2]
I copied the Redirect uri from Django to the geoserver Redirect URI box,
then restarted both tomcat8 and apache2.
Now
http://54.206.23.196/geoserver/web/
gives me a 404 error and the model preview no longer shows the geoserver
layers...
I notice you've run a few more builds overnight. Let me know when you're
ready and I'll try again from scratch.
On 22 January 2018 at 14:05, Alessio Fabiani-2 [via OSGeo.org] <
ml+s1560n5350773h78 at n6.nabble.com> wrote:
> Hi Dave,
> thank you very much for your help and feedbacks.
> From what you reported it seems that the installation process went well it
> is mostly a configuration issue.
> In particular it looks like on GeoNode Admin > Django OAuth Toolkit >
> Applications (http://54.206.23.196/admin/oauth2_provider/application/)
> the "GeoServer" Application is missing the correct "REDIRECT_URI"s
> [image: Immagine incorporata 1]
> In your specific use case you will need to add to the above configured on
> you GeoNode instance, the ones specified on GeoServer oauth2 configuration.
> - Login to GeoServer Admin GUI with admin credentials (by default admin /
> geoserver)
> - Go to Security > Authentication > geonode-oauth2 and make sure the
> "Redirect URI" is listed on GeoNode App
> [image: Immagine incorporata 2]
> Also, if the "geonode-updateip" command went well, you should see here all
> hosts pointing to your public IP. Long story short both GeoServerver and
> GeoNode should report in your case "http://54.206.23.196/geoserver/" as
> Redirect URI.
> *Summary*
> From what you reported - and if you can confirm the steps above fix your
> issue - it looks to me that the problem is on updateip management command
> more than on the installation process.
> In any case this must be improved and fixed. I will double check and do
> more tests on this.
> *Notice*
> On a PUBLIC instance you *must* perform other manual steps before
> exposing it to the web:
> 1. Update the GeoServer by changing:
>      Internal "admin" password - this change must be reflected on GeoNode
> local_settings also
>      Internal "master" password
> 2. Update OAuth2 Client-ID and Client-Secret tokens
>     Update GeoNode GeoServer Oauth2 App
>     Update GeoServer "geonode-oauth2" service accordingly
> 3. Change the GeoNode default "admin" password
>    *warning: *"admin" user must exists. Do not remove it, just change its
> passowrd
>    *note:* "admin" user *is different* from internal GeoServer admin one
> 4- make sure the DB does not use simple passwords and users
> 5- double check the filesystem permissions and secure static / upload
> folders
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa+(LU)+Italy&entry=gmail&source=g>
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> 2018-01-22 8:16 GMT+01:00 Dave Kennewell <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5350773&i=0>>:
>> Hi Alessio,
>> Thanks so much for putting the energy into this. I made two tries to get
>> it working:
>> ___________________________________________________
>> *First attempt*
>> I installed on a fresh 16.04 Ubuntu server EC2 instance on AWS. The
>> package install worked fine (although took +30mins to download the packages
>> - I guess this is normal for a new launchpad repo).
>> However the command
>> IP_ADDRESS=$(ip route get 8.8.8.8 | awk '{print $NF; exit}')
>> will pick up the PRIVATE IP address on an Amazon instance, which leads to
>> "400 Bad Request" errors when trying to access Geonode through the
>> internet.
>> So I run the command instead with the PUBLIC IP:
>> sudo geonode-updateip 54.206.48.105
>> and now it throws and error while "Inspecting the available layers in
>> GeoServer" (apologies, I didn't record the exact error before I terminated
>> the machine & realised that would have been useful!)
>> But, the django part of geonode is accessible now, just not the geoserver
>> parts. I don't think it was valuable to delve into custom config to get a
>> release working, so I tried again from scratch...
>> ____________________________________________________
>> *Second attempt*
>> I terminated the first machine and started again but this time I just
>> updated to the PUBLIC IP:
>> sudo geonode-updateip 54.206.23.196
>> Now there's no errors, and both django and geoserver parts of the app are
>> at least working. I can upload both raster and vector layers, and they will
>> display in the map preview.
>> However a few quick tests show the following bugs:
>> 1. Once I'm logged in to the django app, if I try and log in to the
>> geoserver index page using the geonode button, I get the following error in
>> my browser:
>>> Error: invalid_request
>>> Mismatching redirect URI.
>> 2. The vector layer is displayed in the map preview map (
>> http://54.206.23.196/layers/geonode:model_boundary), but I get pink
>> tiles if I try and "create a map" and view in geoexplorer.  (
>> http://54.206.23.196/maps/new?layer=geonode:model_boundary)
>> I'll leave this instance up & running for a couple of days if you wish to
>> investigate. I can send you superuser details direct if it will help debug,
>> let me know.
>> Thanks again
>> Dave
>> On 19 January 2018 at 17:20, Alessio Fabiani-2 [via OSGeo.org] <[hidden
>> email] <http:///user/SendEmail.jtp?type=node&node=5350773&i=1>> wrote:
>>> Release process ongoing.
>>> For whom willing to try geonode 2.8.0, on a clean Ubuntu 16.04 instance
>>> just run the following commands
>>> sudo add-apt-repository ppa:geonode/testing
>>> sudo apt update
>>> sudo apt install geonode
>>> geonode createsuperuser
>>> sudo geonode-updateip $IP_ADDRESS
>>> sudo service apache2 restart
>>> This is still under testing, so 1. do not try this on production servers
>>> - or on server where you have installations you don't want to break ; 2. it
>>> is possible that something goes wrong - in this case please report to me
>>> Regards,
>>> Alessio Fabiani
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>>> 55054  Massarosa
>>> (LU)
>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa+%3Chttps://maps.google.com/?q%3DVia%2Bdi%2BMontramito%2B3/A%2B55054%2B%25C2%25A0Massarosa%26entry%3Dgmail%26source%3Dg%3E+(LU)+Italy&entry=gmail&source=g>
>>> Italy
>>> phone: <a href="tel:0584%20962313" value="+390584962313"
>>> target="_blank">+39 0584 962313
>>> fax:     <a href="tel:0584%20166%200272" value="+3905841660272"
>>> target="_blank">+39 0584 1660272
>>> mob:   <a href="tel:331%20623%203686" value="+393316233686"
>>> target="_blank">+39 331 6233686
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> 2017-12-23 11:29 GMT+01:00 Paolo Corti <[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=0>>:
>>>> +1!
>>>> of course
>>>> Paolo
>>>> On Fri, Dec 22, 2017 at 12:47 AM, Francesco Bartoli
>>>> <[hidden email] <http:///user/SendEmail.jtp?type=node&node=5350525&i=1>>
>>>> wrote:
>>>> > Hi Rizky,
>>>> > yes you should backport it to 2.7.x which will become 2.8.0 then.
>>>> > Ciao
>>>> > Il giorno 21/dic/2017, alle ore 22:49, Rizky Maulana Nugraha
>>>> > <[hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=2>> ha scritto:
>>>> > +1
>>>> > Can I also know how are you going to release 2.8? Is it coming from
>>>> 2.7.x
>>>> > branch? I would like to include qgis-server backend if possible, but
>>>> that
>>>> > depends on how much effort that would be. At the moment, only master
>>>> branch
>>>> > have qgis-server backend.
>>>> > Software Developer
>>>> > Kartoza.com
>>>> > On Dec 22, 2017 02:15, "Tom Kralidis" <[hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=3>> wrote:
>>>> >> +1
>>>> >> ..Tom
>>>> >> Sent from my iPhone
>>>> >> On Dec 21, 2017, at 14:13, Simone Dalmasso <[hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=4>>
>>>> >> wrote:
>>>> >> +1!
>>>> >> 2017-12-21 19:52 GMT+01:00 Jeremiah Cooper <[hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=5>>:
>>>> >>> +1.
>>>> >>> Thanks.
>>>> >>> Jeremiah Cooper
>>>> >>> On Thu, Dec 21, 2017 at 1:06 PM, Alessio Fabiani
>>>> >>> <[hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=6>> wrote:
>>>> >>>> +1
>>>> >>>> Regards,
>>>> >>>> Alessio Fabiani
>>>> >>>> @alfa7691
>>>> >>>> GeoSolutions S.A.S.
>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+%0D+%3E%3E%3E%3E+55054%C2%A0+Massarosa&entry=gmail&source=g>
>>>> >>>> 55054  Massarosa
>>>> (LU)
>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+%0D+%3E%3E%3E%3E+55054%C2%A0+Massarosa+%3Chttps://maps.google.com/?q%3DVia%2Bdi%2BMontramito%2B3/A%2B%250D%2B%253E%253E%253E%253E%2B55054%25C2%25A0%2BMassarosa%26entry%3Dgmail%26source%3Dg%3E+(LU)+%0D+%3E%3E%3E%3E+Italy&entry=gmail&source=g>
>>>> >>>> Italy
>>>> >>>> phone: <a href="tel:%2B39%200584%20962313" value="<a
>>>> target="_blank">+390584962313"><a href="tel:0584%20962313"
>>>> value="+390584962313" target="_blank">+39 0584 962313
>>>> >>>> fax:     <a href="tel:%2B39%200584%201660272" value="<a
>>>> target="_blank">+3905841660272"><a href="tel:0584%20166%200272"
>>>> value="+3905841660272" target="_blank">+39 0584 1660272
>>>> >>>> mob:   <a href="tel:%2B39%20331%206233686" value="<a
>>>> target="_blank">+393316233686"><a href="tel:331%20623%203686"
>>>> value="+393316233686" target="_blank">+39 331 6233686
>>>> e/o
>>>> riservate. Il loro
>>>> messaggio, per le
>>>> messaggio
>>>> darcene notizia
>>>> >>>> via e-mail e di procedere alla distruzione del messaggio stesso,
>>>> divulgarlo
>>>> utilizzarlo per
>>>> >>>> finalità diverse, costituisce comportamento contrario ai principi
>>>> dettati
>>>> solely
>>>> confidential
>>>> act
>>>> Protection
>>>> reproduction,
>>>> partial, is
>>>> sender does
>>>> or
>>>> changes
>>>> result of
>>>> >>>> On 21 dicembre 2017 17:43, Francesco Bartoli <[hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=7>>
>>>> >>>> wrote:
>>>> >>>>> Hi devs,
>>>> >>>>> as 2.7.x became quite stable we should be ready to move to
>>>> releasing
>>>> >>>>> 2.8.0 as new stable version. Any feedback or concern?
>>>> >>>>> At the moment we don’t have a release manager but Alessio,
>>>> Angelos and
>>>> >>>>> me can volunteer. However it’s likely we need some guidance to
>>>> the overall
>>>> >>>>> procedure.
>>>> >>>>> Thanks and Merry Christmas to all of you
>>>> >>>>> Francesco
>>>> >>>>> geonode-devel mailing list
>>>> >>>>> [hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=8>
>>>> >>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>> >>>> [hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=9>
>>>> >>> [hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=10>
>>>> >> Simone
>>>> >> [hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=11>
>>>> >> [hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=12>
>>>> > [hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=13>
>>>> > [hidden email]
>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=14>
>>>> Paolo Corti
>>>> Geospatial software developer
>>>> web: http://www.paolocorti.net
>>>> twitter: @capooti
>>>> skype: capooti
>>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5350525&i=15>
>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5350525&i=16>
>>> If you reply to this email, your message will be added to the discussion
>>> below:
>>> http://osgeo-org.1560.x6.nabble.com/Move-to-Release-2-8-tp53
>>> 47506p5350525.html
>>> To unsubscribe from GeoNode devel, click here.
>>> NAML
>>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5350773&i=2>
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5350773&i=3>
> below:
> 8-tp5347506p5350773.html
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5185388&code=ZGF2ZWtlbm5ld2VsbEBnbWFpbC5jb218NTE4NTM4OHwtOTI1NjEyMTk0>
> NAML
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180123/eaca715f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180123/eaca715f/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180123/eaca715f/attachment-0003.png>
More information about the geonode-devel
