[GeoNode-devel] Move to Release 2.8
Dave Kennewell
davekennewell at gmail.com
Wed Jan 24 23:28:45 PST 2018
Hi Alessio,
I tried again this morning with a fresh machine using 2.8.0+rc10 - The
install worked fine, however the "sudo geonode-updateip" got a 404 talking
to geoserver:
[image: Inline images 1]
I also get the 404 if I visit the geoserver index page:
http://54.252.237.189/geoserver/index.html
Thanks as always
Dave
On 23 January 2018 at 12:44, Alessio Fabiani-2 [via OSGeo.org] <
ml+s1560n5350910h25 at n6.nabble.com> wrote:
> Hi Dave, hi all,
> about your recent findings, I published 2.8.0rc9 which should fix this
> configuration issue.
> Other than this you don't need now to do "createsuperuser" anymore.
> A standard installation should now be working by just doing this
> sudo add-apt-repository ppa:geonode/testing
> sudo apt update
> sudo apt install geonode
> # For a local installation
> sudo geonode-updateip localhost
> # For a public setup
> IP_ADDRESS=$(ip route get 8.8.8.8 | awk '{print $NF; exit}')
> sudo geonode-updateip $IP_ADDRESS
> # You can also directly specify your public ip address or hostname
> sudo geonode-updateip www.mygeonode.org
> sudo service apache2 restart
> I'm currently looking into trying to automatically set the "local" IP and
> configuration automatically.
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
> 55054 Massarosa
> (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> 2018-01-23 6:29 GMT+01:00 Dave Kennewell <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5350910&i=0>>:
>> Hi Alessio,
>> Yes, I agree it's more a configuration issue than an install issue. The
>> package install worked fine.
>> When I login to the geoserver GUI, the Redirect URI is listed with an
>> additional slash after geoserver:
>> And in
>> Django admin -> Django OAuth Toolkit -> Applications -> GeoServer
>> it lists the Redirect uris without the "/index.html" appended:
>> [image: Inline images 2]
>> I copied the Redirect uri from Django to the geoserver Redirect URI box,
>> then restarted both tomcat8 and apache2.
>> Now
>> http://54.206.23.196/geoserver/web/
>> gives me a 404 error and the model preview no longer shows the geoserver
>> layers...
>> I notice you've run a few more builds overnight. Let me know when you're
>> ready and I'll try again from scratch.
>> On 22 January 2018 at 14:05, Alessio Fabiani-2 [via OSGeo.org] <[hidden
>> email] <http:///user/SendEmail.jtp?type=node&node=5350910&i=1>> wrote:
>>> Hi Dave,
>>> thank you very much for your help and feedbacks.
>>> From what you reported it seems that the installation process went well
>>> it is mostly a configuration issue.
>>> In particular it looks like on GeoNode Admin > Django OAuth Toolkit >
>>> Applications (http://54.206.23.196/admin/oauth2_provider/application/)
>>> the "GeoServer" Application is missing the correct "REDIRECT_URI"s
>>> [image: Immagine incorporata 1]
>>> In your specific use case you will need to add to the above configured
>>> on you GeoNode instance, the ones specified on GeoServer oauth2
>>> configuration.
>>> - Login to GeoServer Admin GUI with admin credentials (by default admin
>>> / geoserver)
>>> - Go to Security > Authentication > geonode-oauth2 and make sure the
>>> "Redirect URI" is listed on GeoNode App
>>> [image: Immagine incorporata 2]
>>> Also, if the "geonode-updateip" command went well, you should see here
>>> all hosts pointing to your public IP. Long story short both GeoServerver
>>> and GeoNode should report in your case "http://54.206.23.196/geoserver/"
>>> as Redirect URI.
>>> *Summary*
>>> From what you reported - and if you can confirm the steps above fix your
>>> issue - it looks to me that the problem is on updateip management command
>>> more than on the installation process.
>>> In any case this must be improved and fixed. I will double check and do
>>> more tests on this.
>>> *Notice*
>>> On a PUBLIC instance you *must* perform other manual steps before
>>> exposing it to the web:
>>> 1. Update the GeoServer by changing:
>>> Internal "admin" password - this change must be reflected on
>>> GeoNode local_settings also
>>> Internal "master" password
>>> 2. Update OAuth2 Client-ID and Client-Secret tokens
>>> Update GeoNode GeoServer Oauth2 App
>>> Update GeoServer "geonode-oauth2" service accordingly
>>> 3. Change the GeoNode default "admin" password
>>> *warning: *"admin" user must exists. Do not remove it, just change
>>> its passowrd
>>> *note:* "admin" user *is different* from internal GeoServer admin one
>>> 4- make sure the DB does not use simple passwords and users
>>> 5- double check the filesystem permissions and secure static / upload
>>> folders
>>> Regards,
>>> Alessio Fabiani
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa+(LU)+Italy&entry=gmail&source=g>
>>> 55054 Massarosa (LU)
>>> Italy
>>> phone: <a href="tel:0584%20962313" value="+390584962313"
>>> target="_blank">+39 0584 962313
>>> fax: <a href="tel:0584%20166%200272" value="+3905841660272"
>>> target="_blank">+39 0584 1660272
>>> mob: <a href="tel:331%20623%203686" value="+393316233686"
>>> target="_blank">+39 331 6233686
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> 2018-01-22 8:16 GMT+01:00 Dave Kennewell <[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5350773&i=0>>:
>>>> Hi Alessio,
>>>> Thanks so much for putting the energy into this. I made two tries to
>>>> get it working:
>>>> ___________________________________________________
>>>> *First attempt*
>>>> I installed on a fresh 16.04 Ubuntu server EC2 instance on AWS. The
>>>> package install worked fine (although took +30mins to download the packages
>>>> - I guess this is normal for a new launchpad repo).
>>>> However the command
>>>> will pick up the PRIVATE IP address on an Amazon instance, which leads
>>>> to "400 Bad Request" errors when trying to access Geonode through the
>>>> internet.
>>>> So I run the command instead with the PUBLIC IP:
>>>> sudo geonode-updateip 54.206.48.105
>>>> and now it throws and error while "Inspecting the available layers in
>>>> GeoServer" (apologies, I didn't record the exact error before I terminated
>>>> the machine & realised that would have been useful!)
>>>> But, the django part of geonode is accessible now, just not the
>>>> geoserver parts. I don't think it was valuable to delve into custom config
>>>> to get a release working, so I tried again from scratch...
>>>> ____________________________________________________
>>>> *Second attempt*
>>>> I terminated the first machine and started again but this time I just
>>>> updated to the PUBLIC IP:
>>>> sudo geonode-updateip 54.206.23.196
>>>> Now there's no errors, and both django and geoserver parts of the app
>>>> are at least working. I can upload both raster and vector layers, and they
>>>> will display in the map preview.
>>>> However a few quick tests show the following bugs:
>>>> 1. Once I'm logged in to the django app, if I try and log in to the
>>>> geoserver index page using the geonode button, I get the following error in
>>>> my browser:
>>>>> Error: invalid_request
>>>>> Mismatching redirect URI.
>>>> 2. The vector layer is displayed in the map preview map (
>>>> http://54.206.23.196/layers/geonode:model_boundary), but I get pink
>>>> tiles if I try and "create a map" and view in geoexplorer. (
>>>> http://54.206.23.196/maps/new?layer=geonode:model_boundary)
>>>> I'll leave this instance up & running for a couple of days if you wish
>>>> to investigate. I can send you superuser details direct if it will help
>>>> debug, let me know.
>>>> Thanks again
>>>> Dave
>>>> On 19 January 2018 at 17:20, Alessio Fabiani-2 [via OSGeo.org] <[hidden
>>>> email] <http:///user/SendEmail.jtp?type=node&node=5350773&i=1>> wrote:
>>>>> Release process ongoing.
>>>>> For whom willing to try geonode 2.8.0, on a clean Ubuntu 16.04
>>>>> instance just run the following commands
>>>>> sudo apt update
>>>>> geonode createsuperuser
>>>>> This is still under testing, so 1. do not try this on production
>>>>> servers - or on server where you have installations you don't want to break
>>>>> ; 2. it is possible that something goes wrong - in this case please report
>>>>> to me
>>>>> Regards,
>>>>> Alessio Fabiani
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> 55054 Massarosa
>>>>> (LU)
>>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa+%3Chttps://maps.google.com/?q%3DVia%2Bdi%2BMontramito%2B3/A%2B55054%2B%25C2%25A0Massarosa%26entry%3Dgmail%26source%3Dg%3E+(LU)+Italy&entry=gmail&source=g>
>>>>> Italy
>>>>> phone: <a href="tel:0584%20962313" value="<a href="tel:0584%20962313"
>>>>> value="+390584962313" target="_blank">+390584962313" target="_blank"><a
>>>>> href="tel:0584%20962313" value="+390584962313" target="_blank">+39 0584
>>>>> 962313
>>>>> fax: <a href="tel:0584%20166%200272" value="<a
>>>>> target="_blank">+3905841660272" target="_blank"><a
>>>>> href="tel:0584%20166%200272" value="+3905841660272" target="_blank">+39
>>>>> 0584 1660272
>>>>> mob: <a href="tel:331%20623%203686" value="<a
>>>>> target="_blank">+393316233686" target="_blank"><a
>>>>> href="tel:331%20623%203686" value="+393316233686" target="_blank">+39 331
>>>>> 6233686
>>>>> 2017-12-23 11:29 GMT+01:00 Paolo Corti <[hidden email]
>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=0>>:
>>>>>> +1!
>>>>>> of course
>>>>>> Paolo
>>>>>> On Fri, Dec 22, 2017 at 12:47 AM, Francesco Bartoli
>>>>>> <[hidden email]
>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=1>> wrote:
>>>>>> > Hi Rizky,
>>>>>> > yes you should backport it to 2.7.x which will become 2.8.0 then.
>>>>>> > Ciao
>>>>>> > Il giorno 21/dic/2017, alle ore 22:49, Rizky Maulana Nugraha
>>>>>> > <[hidden email]
>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=2>> ha scritto:
>>>>>> > +1
>>>>>> > Can I also know how are you going to release 2.8? Is it coming from
>>>>>> 2.7.x
>>>>>> > branch? I would like to include qgis-server backend if possible,
>>>>>> but that
>>>>>> > depends on how much effort that would be. At the moment, only
>>>>>> master branch
>>>>>> > have qgis-server backend.
>>>>>> > Software Developer
>>>>>> > Kartoza.com
>>>>>> > On Dec 22, 2017 02:15, "Tom Kralidis" <[hidden email]
>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=3>> wrote:
>>>>>> >> +1
>>>>>> >> ..Tom
>>>>>> >> Sent from my iPhone
>>>>>> >> On Dec 21, 2017, at 14:13, Simone Dalmasso <[hidden email]
>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=4>>
>>>>>> >> wrote:
>>>>>> >> +1!
>>>>>> >> 2017-12-21 19:52 GMT+01:00 Jeremiah Cooper <[hidden email]
>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=5>>:
>>>>>> >>> +1.
>>>>>> >>> Thanks.
>>>>>> >>> Jeremiah Cooper
>>>>>> >>> On Thu, Dec 21, 2017 at 1:06 PM, Alessio Fabiani
>>>>>> >>> <[hidden email]
>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=6>> wrote:
>>>>>> >>>> +1
>>>>>> >>>> Regards,
>>>>>> >>>> Alessio Fabiani
>>>>>> >>>> @alfa7691
>>>>>> >>>> GeoSolutions S.A.S.
>>>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+%0D+%3E%3E%3E%3E+55054%C2%A0+Massarosa&entry=gmail&source=g>
>>>>>> >>>> 55054 Massarosa
>>>>>> (LU)
>>>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+%0D+%3E%3E%3E%3E+55054%C2%A0+Massarosa+%3Chttps://maps.google.com/?q%3DVia%2Bdi%2BMontramito%2B3/A%2B%250D%2B%253E%253E%253E%253E%2B55054%25C2%25A0%2BMassarosa%26entry%3Dgmail%26source%3Dg%3E+(LU)+%0D+%3E%3E%3E%3E+Italy&entry=gmail&source=g>
>>>>>> >>>> Italy
>>>>>> >>>> phone: <a href="tel:%2B39%200584%20962313" value="<a
>>>>>> target="_blank">+390584962313"><a href="tel:0584%20962313" value="<a
>>>>>> target="_blank">+390584962313" target="_blank">+39 0584 962313
>>>>>> >>>> fax: <a href="tel:%2B39%200584%201660272" value="<a
>>>>>> href="tel:0584%20166%200272" value="<a href="tel:0584%20166%200272"
>>>>>> value="+3905841660272" target="_blank">+3905841660272"
>>>>>> target="_blank">+3905841660272"><a href="tel:0584%20166%200272"
>>>>>> value="<a href="tel:0584%20166%200272" value="+3905841660272"
>>>>>> target="_blank">+3905841660272" target="_blank">+39 0584 1660272
>>>>>> >>>> mob: <a href="tel:%2B39%20331%206233686" value="<a
>>>>>> href="tel:331%20623%203686" value="<a href="tel:331%20623%203686"
>>>>>> value="+393316233686" target="_blank">+393316233686"
>>>>>> target="_blank">+393316233686"><a href="tel:331%20623%203686"
>>>>>> value="<a href="tel:331%20623%203686" value="+393316233686"
>>>>>> target="_blank">+393316233686" target="_blank">+39 331 6233686
>>>>>> elettronica e/o
>>>>>> riservate. Il loro
>>>>>> messaggio, per le
>>>>>> messaggio
>>>>>> darcene notizia
>>>>>> >>>> via e-mail e di procedere alla distruzione del messaggio stesso,
>>>>>> stesso, divulgarlo
>>>>>> utilizzarlo per
>>>>>> principi dettati
>>>>>> solely
>>>>>> confidential
>>>>>> act
>>>>>> Protection
>>>>>> reproduction,
>>>>>> partial, is
>>>>>> contact
>>>>>> sender does
>>>>>> accuracy or
>>>>>> changes
>>>>>> result of
>>>>>> >>>> On 21 dicembre 2017 17:43, Francesco Bartoli <[hidden email]
>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=7>>
>>>>>> >>>> wrote:
>>>>>> >>>>> Hi devs,
>>>>>> >>>>> as 2.7.x became quite stable we should be ready to move to
>>>>>> releasing
>>>>>> >>>>> 2.8.0 as new stable version. Any feedback or concern?
>>>>>> >>>>> At the moment we don’t have a release manager but Alessio,
>>>>>> Angelos and
>>>>>> >>>>> me can volunteer. However it’s likely we need some guidance to
>>>>>> the overall
>>>>>> >>>>> procedure.
>>>>>> >>>>> Thanks and Merry Christmas to all of you
>>>>>> >>>>> Francesco
>>>>>> >>>>> geonode-devel mailing list
>>>>>> >>>>> [hidden email]
>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=8>
>>>>>> >>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>> >>>> [hidden email]
>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=9>
>>>>>> >>> [hidden email]
>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=10>
>>>>>> >> Simone
>>>>>> >> [hidden email]
>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=11>
>>>>>> >> [hidden email]
>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=12>
>>>>>> > [hidden email]
>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=13>
>>>>>> > [hidden email]
>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=14>
>>>>>> Paolo Corti
>>>>>> Geospatial software developer
>>>>>> web: http://www.paolocorti.net
>>>>>> twitter: @capooti
>>>>>> skype: capooti
>>>>>> [hidden email]
>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=15>
>>>>> [hidden email]
>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=16>
>>>>> If you reply to this email, your message will be added to the
>>>>> discussion below:
>>>>> http://osgeo-org.1560.x6.nabble.com/Move-to-Release-2-8-tp53
>>>>> 47506p5350525.html
>>>>> To unsubscribe from GeoNode devel, click here.
>>>>> NAML
>>>>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5350773&i=2>
>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5350773&i=3>
>>> If you reply to this email, your message will be added to the discussion
>>> below:
>>> 47506p5350773.html
>>> NAML
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5350910&i=2>
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5350910&i=3>
> below:
> 8-tp5347506p5350910.html
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5185388&code=ZGF2ZWtlbm5ld2VsbEBnbWFpbC5jb218NTE4NTM4OHwtOTI1NjEyMTk0>
> NAML
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180125/c5e75aad/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180125/c5e75aad/attachment-0001.png>
More information about the geonode-devel
