[GeoNode-devel] Move to Release 2.8
Jeremiah Cooper
jcooper at jeremiahcooper.com
Tue Jan 30 14:52:56 PST 2018
I would agree - it would be nice to see 2.8.x on Django 1.11.
Thanks.
Jeremiah Cooper
On Tue, Jan 30, 2018 at 5:39 PM, Olivier Dalang <olivier.dalang at gmail.com>
wrote:
> Hello !
> Django 1.8 LTS reaches end of support in April 2018, which means no more
> fixes at all (even security fixes).
> I think it would be nice to support 1.11 (which is the current LTS) before
> releasing a new version of Geonode. Django 1.11 is probably now old enough
> so that most third party apps would be compatible, and is still supporting
> python 2, so it may be a reasonable amount of work.
> Has anyone already worked on this yet ? I have only migrated smaller
> Django projects, so I may be underestimating how much work this is...
> Kind regards,
> Olivier
> On Thu, Jan 25, 2018 at 9:23 PM, Alessio Fabiani <alessio.fabiani at geo-
> solutions.it> wrote:
>> Ok Francesco,
>> I will put some more consistency checks on the bash scripts then.
>> Regards,
>> Alessio Fabiani
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054 Massarosa (LU)
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax: +39 0584 1660272 <+39%200584%20166%200272>
>> mob: +39 331 6233686 <+39%20331%20623%203686>
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> 2018-01-25 10:19 GMT+01:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> Alessio,
>>> I confirm the error from Dave, which is saying the geoserver context
>>> from Tomcat has been lost somehow. If I remember well you had the same
>>> error initially just after started the alpha release right?
>>> Francesco
>>> Il 25 gen 2018, 10:13 +0100, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it>, ha scritto:
>>> Uhmm, yes it is possible.
>>> Did not get such error on my previous tests, but I will investigate more
>>> by using your cathed stacktrace.
>>> Thanks for reporting.
>>> Regards,
>>> Alessio Fabiani
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>>> 55054
>>> Massarosa
>>> (LU)
>>> Italy
>>> fax: +39 0584 1660272 <+39%200584%201660272>
>>> mob: +39 331 6233686 <+39%20331%206233686>
>>> 2018-01-25 10:03 GMT+01:00 Dave Kennewell <davekennewell at gmail.com>:
>>>> First question - yes I confirm I typed the
>>>> sudo geonode-updateip 54.252.237.189
>>>> Second question - regards "is geoserver running":
>>>> sudo service tomcat8 status shows tomcat8 is running fine, and wget to
>>>> http://localhost:8080 establishes a connection with something, but it
>>>> returns the 404.
>>>> [image: Inline images 1]
>>>> HOWEVER, after restarting tomcat8 manually (sudo service tomcat8
>>>> restart), geoserver now is responsive.
>>>> So it appears there is something in the configuration that is
>>>> preventing geoserver from starting properly during the "sudo
>>>> geonode-updateip" command?
>>>> On 25 January 2018 at 12:42, Alessio Fabiani-2 [via OSGeo.org] <
>>>> ml+s1560n5351221h66 at n6.nabble.com> wrote:
>>>>> However from the logs it looks like geoserver is not running on port
>>>>> 8080 ? Can you double check?
>>>>> Regards,
>>>>> Alessio Fabiani
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> 55054 Massarosa
>>>>> (LU)
>>>>> Italy
>>>>> phone: +39 0584 962313 <0584%20962313>
>>>>> fax: +39 0584 1660272 <0584%20166%200272>
>>>>> mob: +39 331 6233686 <331%20623%203686>
>>>>> 2018-01-25 9:40 GMT+01:00 Alessio Fabiani <[hidden email]
>>>>> <http:///user/SendEmail.jtp?type=node&node=5351221&i=0>>:
>>>>>> Hi Dave,
>>>>>> did you run
>>>>>> Regards,
>>>>>> Alessio Fabiani
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> 55054 Massarosa
>>>>>> (LU)
>>>>>> Italy
>>>>>> phone: <a href="tel:0584%20962313" value="+390584962313
>>>>>> <0584%20962313>" target="_blank">+39 0584 962313 <0584%20962313>
>>>>>> fax: <a href="tel:0584%20166%200272" value="+3905841660272
>>>>>> <0584%20166%200272>" target="_blank">+39 0584 1660272
>>>>>> <0584%20166%200272>
>>>>>> mob: <a href="tel:331%20623%203686" value="+393316233686
>>>>>> <331%20623%203686>" target="_blank">+39 331 6233686
>>>>>> <331%20623%203686>
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> 2018-01-25 8:28 GMT+01:00 Dave Kennewell <[hidden email]
>>>>>> <http:///user/SendEmail.jtp?type=node&node=5351221&i=1>>:
>>>>>>> Hi Alessio,
>>>>>>> I tried again this morning with a fresh machine using 2.8.0+rc10 -
>>>>>>> The install worked fine, however the "sudo geonode-updateip" got a 404
>>>>>>> talking to geoserver:
>>>>>>> I also get the 404 if I visit the geoserver index page:
>>>>>>> http://54.252.237.189/geoserver/index.html
>>>>>>> Thanks as always
>>>>>>> Dave
>>>>>>> On 23 January 2018 at 12:44, Alessio Fabiani-2 [via OSGeo.org] <[hidden
>>>>>>> email] <http:///user/SendEmail.jtp?type=node&node=5351221&i=2>>
>>>>>>> wrote:
>>>>>>>> Hi Dave, hi all,
>>>>>>>> about your recent findings, I published 2.8.0rc9 which should fix
>>>>>>>> this configuration issue.
>>>>>>>> Other than this you don't need now to do "createsuperuser" anymore.
>>>>>>>> A standard installation should now be working by just doing this
>>>>>>>> sudo add-apt-repository ppa:geonode/testing
>>>>>>>> sudo apt update
>>>>>>>> sudo apt install geonode
>>>>>>>> # For a local installation
>>>>>>>> sudo geonode-updateip localhost
>>>>>>>> # For a public setup
>>>>>>>> IP_ADDRESS=$(ip route get 8.8.8.8 | awk '{print $NF; exit}')
>>>>>>>> sudo geonode-updateip $IP_ADDRESS
>>>>>>>> # You can also directly specify your public ip address or hostname
>>>>>>>> sudo geonode-updateip www.mygeonode.org
>>>>>>>> sudo service apache2 restart
>>>>>>>> I'm currently looking into trying to automatically set the "local"
>>>>>>>> IP and configuration automatically.
>>>>>>>> Regards,
>>>>>>>> Alessio Fabiani
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> 55054 Massarosa
>>>>>>>> (LU)
>>>>>>>> Italy
>>>>>>>> 2018-01-23 6:29 GMT+01:00 Dave Kennewell <[hidden email]
>>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350910&i=0>>:
>>>>>>>>> Hi Alessio,
>>>>>>>>> Yes, I agree it's more a configuration issue than an install
>>>>>>>>> issue. The package install worked fine.
>>>>>>>>> When I login to the geoserver GUI, the Redirect URI is listed with
>>>>>>>>> an additional slash after geoserver:
>>>>>>>>> And in
>>>>>>>>> Django admin -> Django OAuth Toolkit -> Applications -> GeoServer
>>>>>>>>> it lists the Redirect uris without the "/index.html" appended:
>>>>>>>>> [image: Inline images 2]
>>>>>>>>> I copied the Redirect uri from Django to the geoserver Redirect
>>>>>>>>> URI box, then restarted both tomcat8 and apache2.
>>>>>>>>> Now
>>>>>>>>> http://54.206.23.196/geoserver/web/
>>>>>>>>> gives me a 404 error and the model preview no longer shows the
>>>>>>>>> geoserver layers...
>>>>>>>>> I notice you've run a few more builds overnight. Let me know when
>>>>>>>>> you're ready and I'll try again from scratch.
>>>>>>>>> On 22 January 2018 at 14:05, Alessio Fabiani-2 [via OSGeo.org] <[hidden
>>>>>>>>> email] <http:///user/SendEmail.jtp?type=node&node=5350910&i=1>>
>>>>>>>>> wrote:
>>>>>>>>>> Hi Dave,
>>>>>>>>>> thank you very much for your help and feedbacks.
>>>>>>>>>> From what you reported it seems that the installation process
>>>>>>>>>> went well it is mostly a configuration issue.
>>>>>>>>>> In particular it looks like on GeoNode Admin > Django OAuth
>>>>>>>>>> Toolkit > Applications (http://54.206.23.196/admin/oa
>>>>>>>>>> uth2_provider/application/) the "GeoServer" Application is
>>>>>>>>>> missing the correct "REDIRECT_URI"s
>>>>>>>>>> [image: Immagine incorporata 1]
>>>>>>>>>> In your specific use case you will need to add to the above
>>>>>>>>>> configured on you GeoNode instance, the ones specified on GeoServer oauth2
>>>>>>>>>> configuration.
>>>>>>>>>> - Login to GeoServer Admin GUI with admin credentials (by default
>>>>>>>>>> admin / geoserver)
>>>>>>>>>> - Go to Security > Authentication > geonode-oauth2 and make sure
>>>>>>>>>> the "Redirect URI" is listed on GeoNode App
>>>>>>>>>> [image: Immagine incorporata 2]
>>>>>>>>>> Also, if the "geonode-updateip" command went well, you should see
>>>>>>>>>> here all hosts pointing to your public IP. Long story short both
>>>>>>>>>> GeoServerver and GeoNode should report in your case "
>>>>>>>>>> http://54.206.23.196/geoserver/" as Redirect URI.
>>>>>>>>>> *Summary*
>>>>>>>>>> From what you reported - and if you can confirm the steps above
>>>>>>>>>> fix your issue - it looks to me that the problem is on updateip management
>>>>>>>>>> command more than on the installation process.
>>>>>>>>>> In any case this must be improved and fixed. I will double check
>>>>>>>>>> and do more tests on this.
>>>>>>>>>> *Notice*
>>>>>>>>>> On a PUBLIC instance you *must* perform other manual steps
>>>>>>>>>> before exposing it to the web:
>>>>>>>>>> 1. Update the GeoServer by changing:
>>>>>>>>>> Internal "admin" password - this change must be reflected on
>>>>>>>>>> GeoNode local_settings also
>>>>>>>>>> Internal "master" password
>>>>>>>>>> 2. Update OAuth2 Client-ID and Client-Secret tokens
>>>>>>>>>> Update GeoNode GeoServer Oauth2 App
>>>>>>>>>> Update GeoServer "geonode-oauth2" service accordingly
>>>>>>>>>> 3. Change the GeoNode default "admin" password
>>>>>>>>>> *warning:* "admin" user must exists. Do not remove it, just
>>>>>>>>>> change its passowrd
>>>>>>>>>> *note:* "admin" user *is different* from internal GeoServer
>>>>>>>>>> admin one
>>>>>>>>>> 4- make sure the DB does not use simple passwords and users
>>>>>>>>>> 5- double check the filesystem permissions and secure static /
>>>>>>>>>> upload folders
>>>>>>>>>> Regards,
>>>>>>>>>> Alessio Fabiani
>>>>>>>>>> @alfa7691
>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa+(LU)+Italy&entry=gmail&source=g>
>>>>>>>>>> Italy
>>>>>>>>>> phone: <a href="tel:0584%20962313" value="<a
>>>>>>>>>> href="tel:0584%20962313" value="+390584962313 <0584%20962313>"
>>>>>>>>>> target="_blank">+390584962313" target="_blank"><a
>>>>>>>>>> href="tel:0584%20962313" value="+390584962313" target="_blank">+39
>>>>>>>>>> fax: <a href="tel:0584%20166%200272" value="<a
>>>>>>>>>> <0584%20166%200272>" target="_blank">+3905841660272"
>>>>>>>>>> target="_blank"><a href="tel:0584%20166%200272" value="
>>>>>>>>>> +3905841660272 <0584%20166%200272>" target="_blank">+39 0584
>>>>>>>>>> mob: <a href="tel:331%20623%203686" value="<a
>>>>>>>>>> <331%20623%203686>" target="_blank">+393316233686"
>>>>>>>>>> target="_blank"><a href="tel:331%20623%203686" value="
>>>>>>>>>> +393316233686" target="_blank">+39 331 6233686
>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>> 2018-01-22 8:16 GMT+01:00 Dave Kennewell <[hidden email]
>>>>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350773&i=0>>:
>>>>>>>>>>> Hi Alessio,
>>>>>>>>>>> Thanks so much for putting the energy into this. I made two
>>>>>>>>>>> tries to get it working:
>>>>>>>>>>> ___________________________________________________
>>>>>>>>>>> *First attempt*
>>>>>>>>>>> I installed on a fresh 16.04 Ubuntu server EC2 instance on AWS.
>>>>>>>>>>> The package install worked fine (although took +30mins to download the
>>>>>>>>>>> packages - I guess this is normal for a new launchpad repo).
>>>>>>>>>>> However the command
>>>>>>>>>>> will pick up the PRIVATE IP address on an Amazon instance, which
>>>>>>>>>>> leads to "400 Bad Request" errors when trying to access Geonode through the
>>>>>>>>>>> internet.
>>>>>>>>>>> So I run the command instead with the PUBLIC IP:
>>>>>>>>>>> sudo geonode-updateip 54.206.48.105
>>>>>>>>>>> and now it throws and error while "Inspecting the available
>>>>>>>>>>> layers in GeoServer" (apologies, I didn't record the exact error before I
>>>>>>>>>>> terminated the machine & realised that would have been useful!)
>>>>>>>>>>> But, the django part of geonode is accessible now, just not the
>>>>>>>>>>> geoserver parts. I don't think it was valuable to delve into custom config
>>>>>>>>>>> to get a release working, so I tried again from scratch...
>>>>>>>>>>> ____________________________________________________
>>>>>>>>>>> *Second attempt*
>>>>>>>>>>> I terminated the first machine and started again but this time I
>>>>>>>>>>> just updated to the PUBLIC IP:
>>>>>>>>>>> sudo geonode-updateip 54.206.23.196
>>>>>>>>>>> Now there's no errors, and both django and geoserver parts of
>>>>>>>>>>> the app are at least working. I can upload both raster and vector layers,
>>>>>>>>>>> and they will display in the map preview.
>>>>>>>>>>> However a few quick tests show the following bugs:
>>>>>>>>>>> 1. Once I'm logged in to the django app, if I try and log in to
>>>>>>>>>>> the geoserver index page using the geonode button, I get the following
>>>>>>>>>>> error in my browser:
>>>>>>>>>>>> Error: invalid_request
>>>>>>>>>>>> Mismatching redirect URI.
>>>>>>>>>>> 2. The vector layer is displayed in the map preview map (
>>>>>>>>>>> http://54.206.23.196/layers/geonode:model_boundary), but I get
>>>>>>>>>>> pink tiles if I try and "create a map" and view in geoexplorer. (
>>>>>>>>>>> http://54.206.23.196/maps/new?layer=geonode:model_boundary)
>>>>>>>>>>> I'll leave this instance up & running for a couple of days if
>>>>>>>>>>> you wish to investigate. I can send you superuser details direct if it will
>>>>>>>>>>> help debug, let me know.
>>>>>>>>>>> Thanks again
>>>>>>>>>>> Dave
>>>>>>>>>>> On 19 January 2018 at 17:20, Alessio Fabiani-2 [via OSGeo.org] <[hidden
>>>>>>>>>>> email] <http:///user/SendEmail.jtp?type=node&node=5350773&i=1>>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> Release process ongoing.
>>>>>>>>>>>> For whom willing to try geonode 2.8.0, on a clean Ubuntu 16.04
>>>>>>>>>>>> instance just run the following commands
>>>>>>>>>>>> sudo apt update
>>>>>>>>>>>> geonode createsuperuser
>>>>>>>>>>>> This is still under testing, so 1. do not try this on
>>>>>>>>>>>> production servers - or on server where you have installations you don't
>>>>>>>>>>>> want to break ; 2. it is possible that something goes wrong - in this case
>>>>>>>>>>>> please report to me
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Alessio Fabiani
>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>> 55054 Massarosa
>>>>>>>>>>>> (LU)
>>>>>>>>>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa+%3Chttps://maps.google.com/?q%3DVia%2Bdi%2BMontramito%2B3/A%2B55054%2B%25C2%25A0Massarosa%26entry%3Dgmail%26source%3Dg%3E+(LU)+Italy&entry=gmail&source=g>
>>>>>>>>>>>> Italy
>>>>>>>>>>>> href="tel:0584%20962313" value="<a href="tel:0584%20962313" value="
>>>>>>>>>>>> +390584962313 <0584%20962313>" target="_blank">+390584962313"
>>>>>>>>>>>> target="_blank"><a href="tel:0584%20962313" value="
>>>>>>>>>>>> +390584962313" target="_blank">+390584962313"
>>>>>>>>>>>> target="_blank"><a href="tel:0584%20962313" value="<a
>>>>>>>>>>>> +390584962313" target="_blank"><a href="tel:0584%20962313"
>>>>>>>>>>>> value="+390584962313" target="_blank">+39 0584 962313
>>>>>>>>>>>> href="tel:0584%20166%200272" value="<a href="tel:0584%20166%200272" value="
>>>>>>>>>>>> +3905841660272" target="_blank"><a
>>>>>>>>>>>> target="_blank"><a href="tel:0584%20166%200272" value="<a
>>>>>>>>>>>> href="tel:331%20623%203686" value="<a href="tel:331%20623%203686" value="
>>>>>>>>>>>> +393316233686 <331%20623%203686>" target="_blank">+393316233686"
>>>>>>>>>>>> +393316233686" target="_blank">+393316233686"
>>>>>>>>>>>> target="_blank"><a href="tel:331%20623%203686" value="<a
>>>>>>>>>>>> href="tel:331%20623%203686" value="+393316233686"
>>>>>>>>>>>> target="_blank">+393316233686" target="_blank"><a
>>>>>>>>>>>> target="_blank">+39 331 6233686 <+39%20331%206233686>
>>>>>>>>>>>> 2017-12-23 11:29 GMT+01:00 Paolo Corti <[hidden email]
>>>>>>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=0>>:
>>>>>>>>>>>>> +1!
>>>>>>>>>>>>> of course
>>>>>>>>>>>>> Paolo
>>>>>>>>>>>>> On Fri, Dec 22, 2017 at 12:47 AM, Francesco Bartoli
>>>>>>>>>>>>> <[hidden email]
>>>>>>>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=1>>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> > Hi Rizky,
>>>>>>>>>>>>> > yes you should backport it to 2.7.x which will become 2.8.0
>>>>>>>>>>>>> then.
>>>>>>>>>>>>> > Ciao
>>>>>>>>>>>>> > Il giorno 21/dic/2017, alle ore 22:49, Rizky Maulana Nugraha
>>>>>>>>>>>>> > <[hidden email]
>>>>>>>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=2>> ha
>>>>>>>>>>>>> scritto:
>>>>>>>>>>>>> > +1
>>>>>>>>>>>>> > Can I also know how are you going to release 2.8? Is it
>>>>>>>>>>>>> coming from 2.7.x
>>>>>>>>>>>>> > branch? I would like to include qgis-server backend if
>>>>>>>>>>>>> possible, but that
>>>>>>>>>>>>> > depends on how much effort that would be. At the moment,
>>>>>>>>>>>>> only master branch
>>>>>>>>>>>>> > have qgis-server backend.
>>>>>>>>>>>>> > Software Developer
>>>>>>>>>>>>> > Kartoza.com
>>>>>>>>>>>>> > On Dec 22, 2017 02:15, "Tom Kralidis" <[hidden email]
>>>>>>>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=3>>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> >> +1
>>>>>>>>>>>>> >> ..Tom
>>>>>>>>>>>>> >> Sent from my iPhone
>>>>>>>>>>>>> >> On Dec 21, 2017, at 14:13, Simone Dalmasso <[hidden email]
>>>>>>>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=4>>
>>>>>>>>>>>>> >> wrote:
>>>>>>>>>>>>> >> +1!
>>>>>>>>>>>>> >> 2017-12-21 19:52 GMT+01:00 Jeremiah Cooper <[hidden email]
>>>>>>>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=5>>:
>>>>>>>>>>>>> >>> +1.
>>>>>>>>>>>>> >>> Thanks.
>>>>>>>>>>>>> >>> Jeremiah Cooper
>>>>>>>>>>>>> >>> On Thu, Dec 21, 2017 at 1:06 PM, Alessio Fabiani
>>>>>>>>>>>>> >>> <[hidden email]
>>>>>>>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=6>>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> >>>> +1
>>>>>>>>>>>>> >>>> Regards,
>>>>>>>>>>>>> >>>> Alessio Fabiani
>>>>>>>>>>>>> >>>> @alfa7691
>>>>>>>>>>>>> >>>> GeoSolutions S.A.S.
>>>>>>>>>>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+%0D+%3E%3E%3E%3E+55054%C2%A0+Massarosa&entry=gmail&source=g>
>>>>>>>>>>>>> >>>> 55054 Massarosa
>>>>>>>>>>>>> (LU)
>>>>>>>>>>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+%0D+%3E%3E%3E%3E+55054%C2%A0+Massarosa+%3Chttps://maps.google.com/?q%3DVia%2Bdi%2BMontramito%2B3/A%2B%250D%2B%253E%253E%253E%253E%2B55054%25C2%25A0%2BMassarosa%26entry%3Dgmail%26source%3Dg%3E+(LU)+%0D+%3E%3E%3E%3E+Italy&entry=gmail&source=g>
>>>>>>>>>>>>> >>>> Italy
>>>>>>>>>>>>> >>>> phone: <a href="tel:%2B39%200584%20962313" value="<a
>>>>>>>>>>>>> href="tel:0584%20962313" value="<a href="tel:0584%20962313" value="<a
>>>>>>>>>>>>> +390584962313" target="_blank">+390584962313 <0584%20962313>"><a
>> [Message clipped]
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180130/e7af1feb/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180130/e7af1feb/attachment-0001.png>
More information about the geonode-devel
