[GeoNode-devel] [GeoNode-users] Geonode Unable to Sign in
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu May 10 01:08:11 PDT 2018
Hello Julieme,
it looks to me that there's some issue on your setup.
Sorry to jump into the discussion only now. Can you please quickly
summarize how you installed and configured the system?
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
2018-05-10 0:10 GMT+02:00 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com>:
> The response is the same to python manage.py shell
> I have no idea about what is going on. Any help on that would be very
> appreciated.
> Thank you very much for your help and time.
> Kind regards
> 2018-05-09 18:58 GMT-03:00 Julierme Pinheiro <juliermeopensourcedeveloper@
> gmail.com>:
>> Hi Faneva,
>> I have tried all these commands:
>> python manage.py createsuperuser
>> python manage.py changepassword admin
>> And the response to both is:
>> Traceback (most recent call last):
>> File "manage.py", line 31, in <module>
>> execute_from_command_line(sys.argv)
>> File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py",
>> line 354, in execute_from_command_line
>> utility.execute()
>> line 303, in execute
>> settings.INSTALLED_APPS
>> File "/usr/local/lib/python2.7/dist-packages/django/conf/__init__.py",
>> line 48, in __getattr__
>> self._setup(name)
>> line 44, in _setup
>> self._wrapped = Settings(settings_module)
>> line 92, in __init__
>> mod = importlib.import_module(self.SETTINGS_MODULE)
>> File "/usr/lib/python2.7/importlib/__init__.py", line 37, in
>> import_module
>> __import__(name)
>> File "/home/geonode/my_geonode/my_geonode/settings.py", line 27, in
>> <module>
>> from geonode.settings import *
>> ImportError: No module named geonode.settings
>> I have no idea in what is going on. Any help on that would be very
>> appreciated.
>> Kind regards
>> Julierme
>> 2018-05-09 18:50 GMT-03:00 ANDRIAMIADANTSOA Fanevanjanahary <
>> fanevanjanahary at gmail.com>:
>>> Hello Julierme,
>>> Did you already try to change the admin's password?
>>> This is commande to change this
>>> Best regards
>>> Faneva
>>> On Thu, May 10, 2018, 00:21 Julierme Pinheiro <
>>> juliermeopensourcedeveloper at gmail.com> wrote:
>>>> Hi all,
>>>> I finally got the end of the geonode installation as in here:
>>>> http://docs.geonode.org/en/master/tutorials/install_and_admi
>>>> n/geonode_install/all_together.html
>>>> But now, I am unable to sign in. The tutorial says: Login with admin
>>>> username and password you just set. But I do not remember setting an
>>>> username and a password during the installation. I tried the default one:
>>>> username:admin and password: admin, but I got no success.
>>>> Any help on that please?
>>>> Thank you for your time in advance.
>>>> Best regards
>>>> Julierme
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180510/1ce33f76/attachment-0001.html>
More information about the geonode-devel
