[GeoNode-devel] Unable to install correctly geonode2.8 in remote VM (Toni Schönbuchner)
Dimitris Kar dkarakostis at gmail.com
Thu May 24 08:09:09 PDT 2018
Actually this command:
ip route get 8.8.8.8 | awk '{print $NF; exit}' returns the internal IP of
the VM. Is this correct?
On Thu, May 24, 2018 at 5:05 PM, Dimitris Kar <dkarakostis at gmail.com> wrote:
> Hey Alessio,
> I used the Quick Installation Guide (http://docs.geonode.org/en/
> master/tutorials/install_and_admin/quick_install.html):
> 1. sudo apt-get update; sudo apt-get upgrade
> 2. sudo add-apt-repository ppa:geonode/stable
> 3. sudo apt-get update; sudo apt-get upgrade; sudo apt-get autoremove
>    sudo apt-get install geonode
> 4.IP_ADDRESS=$(ip route get 8.8.8.8 | awk ‘{print $NF; exit}’)
> sudo geonode-updateip $IP_ADDRESS
> The installation is in an ubuntu-1604-xenial from google cloud platform.
> On Thu, May 24, 2018 at 10:12 AM, Alessio Fabiani <alessio.fabiani at geo-
> solutions.it> wrote:
>> However from a quick look at the stack trace, it seems to me the the
>> error might be related to a misconfiguration of the ALLOWED_HOSTS
>> parameter. Just guessing.
>> Regards,
>> Alessio Fabiani
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>> 55054  Massarosa
>> (LU)
>> Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> 2018-05-24 10:11 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions
>> .it>:
>>> Hello Dimitris,
>>> sorry to jump so late into the discussion. I am a bit lost, could I ask
>>> you to briefly summarize the steps you followed to install GeoNode? Did you
>>> use the custom project or something?
>>> Regards,
>>> Alessio Fabiani
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> 55054  Massarosa
>>> (LU)
>>> Italy
>>> 2018-05-24 8:51 GMT+02:00 Dimitris Kar <dkarakostis at gmail.com>:
>>>> Yes. debug parameter was set to true. I changed that to False (both in
>>>> local_settings.py and settings.py). I have also checked my apache2 conf
>>>> file for geonode (/etc/apache2/sites-available/geonode.conf). All the
>>>> directories there point to the www folder (*/var/www/geonode/uploaded/*).
>>>> The owner of the www folder is www-data.
>>>> This is how geonode.conf file looks like (generated by the geonode
>>>> installation):
>>>> WSGIDaemonProcess geonode user=www-data threads=15 processes=2
>>>> <VirtualHost *:80>
>>>>     Servername localhost
>>>>     ServerAdmin webmaster at localhost
>>>>     DocumentRoot /var/www/geonode
>>>>     LimitRequestFieldSize 32760
>>>>     LimitRequestLine 32760
>>>>     ErrorLog /var/log/apache2/error.log
>>>>     LogLevel warn
>>>>     CustomLog /var/log/apache2/access.log combined
>>>>     WSGIProcessGroup geonode
>>>>     WSGIPassAuthorization On
>>>>     WSGIScriptAlias / /var/www/geonode/wsgi/geonode.wsgi
>>>>     <Directory "/var/www/geonode/">
>>>>         <Files wsgi.py>
>>>>              Order deny,allow
>>>>              Allow from all
>>>>              Require all granted
>>>>          </Files>
>>>>         Order allow,deny
>>>>         Options Indexes FollowSymLinks
>>>>         Allow from all
>>>>         IndexOptions FancyIndexing
>>>>     </Directory>
>>>>     Alias /static/ /var/www/geonode/static/
>>>>     Alias /uploaded/ /var/www/geonode/uploaded/
>>>>     Alias /robots.txt /var/www/geonode/robots.txt
>>>>     <Directory "/var/www/geonode/uploaded/documents/">
>>>>         Order allow,deny
>>>>         Allow from all
>>>>         Require all granted
>>>>     </Directory>
>>>>    <Directory "/var/www/geonode/uploaded/layers/">
>>>>         Order allow,deny
>>>>         Allow from all
>>>>         Require all granted
>>>>     </Directory>
>>>>     <Directory "/var/www/geonode/static_root/">
>>>>         Order allow,deny
>>>>         Allow from all
>>>>         Require all granted
>>>>     </Directory>
>>>>     <Directory "/var/www/geonode/uploaded/thumbs/">
>>>>         Order allow,deny
>>>>         Allow from all
>>>>         Require all granted
>>>>     </Directory>
>>>>     <Directory "/var/www/geonode/uploaded/avatars/">
>>>>         Order allow,deny
>>>>         Allow from all
>>>>         Require all granted
>>>>     </Directory>
>>>>     <Directory "/var/www/geonode/uploaded/people_group/">
>>>>         Order allow,deny
>>>>         Allow from all
>>>>         Require all granted
>>>>     </Directory>
>>>>     <Directory "/var/www/geonode/uploaded/group/">
>>>>         Order allow,deny
>>>>         Allow from all
>>>>         Require all granted
>>>>     </Directory>
>>>>     <Proxy *>
>>>>       Order allow,deny
>>>>       Allow from all
>>>>     </Proxy>
>>>>     ProxyPreserveHost On
>>>>     ProxyPass /geoserver http://localhost:8080/geoserver
>>>>     ProxyPassReverse /geoserver http://localhost:8080/geoserver
>>>> </VirtualHost>
>>>> On Tue, May 22, 2018 at 8:58 PM, Simone Dalmasso <
>>>> simone.dalmasso at gmail.com> wrote:
>>>>> Hm do you have debug set to true? This could be one reason but also
>>>>> looks like the Apache rules for the static folders aren’t correctly set as
>>>>> well. Check also that one. Django is trying to deal with your css rather
>>>>> than Apache but in production it shouldn’t be.
>>>>> Il giorno mar 22 mag 2018 alle 18:17 Dimitris Kar <
>>>>> dkarakostis at gmail.com> ha scritto:
>>>>>> Ciao Simone,
>>>>>> When I try to access one of these links it actually reloads the home
>>>>>> page. I would expect to show some css code but instead in redirects to the
>>>>>> homepage.
>>>>>> Regarding the apache.log file these are the errors on page load.
>>>>>> [Tue May 22 11:05:53.044719 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708141008640] Traceback (most recent call last):
>>>>>> [Tue May 22 11:05:53.044723 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708141008640]   File "/usr/lib/python2.7/dist-packa
>>>>>> ges/django/core/handlers/base.py", line 108, in get_response
>>>>>> [Tue May 22 11:05:53.044727 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708141008640]     response = middleware_method(request)
>>>>>> [Tue May 22 11:05:53.044730 2018] [wsgi:error] [pid 22852:tid
>>>>>> ges/django/middleware/common.py", line 62, in process_request
>>>>>> [Tue May 22 11:05:53.044734 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708141008640]     host = request.get_host()
>>>>>> [Tue May 22 11:05:53.044737 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708141008640]   File "/usr/lib/python2.7/dist-packages/django/http/request.py",
>>>>>> line 94, in get_host
>>>>>> [Tue May 22 11:05:53.044741 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708141008640]     if domain and validate_host(domain, allowed_hosts):
>>>>>> [Tue May 22 11:05:53.044744 2018] [wsgi:error] [pid 22852:tid
>>>>>> line 571, in validate_host
>>>>>> [Tue May 22 11:05:53.044759 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708141008640]     pattern = pattern.lower()
>>>>>> [Tue May 22 11:05:53.044762 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708141008640] AttributeError: 'NoneType' object has no attribute 'lower'
>>>>>> [Tue May 22 11:06:14.450424 2018] [wsgi:error] [pid 22853:tid
>>>>>> 139708250121984] Internal Server Error: /lib/css/assets.min.css
>>>>>> [Tue May 22 11:06:14.450684 2018] [wsgi:error] [pid 22853:tid
>>>>>> 139708250121984] Traceback (most recent call last):
>>>>>> [Tue May 22 11:06:14.450747 2018] [wsgi:error] [pid 22853:tid
>>>>>> 139708250121984]   File "/usr/lib/python2.7/dist-packa
>>>>>> [Tue May 22 11:06:14.450796 2018] [wsgi:error] [pid 22853:tid
>>>>>> 139708250121984]     response = middleware_method(request)
>>>>>> [Tue May 22 11:06:14.450847 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.450893 2018] [wsgi:error] [pid 22853:tid
>>>>>> 139708250121984]     host = request.get_host()
>>>>>> [Tue May 22 11:06:14.450948 2018] [wsgi:error] [pid 22853:tid
>>>>>> 139708250121984]   File "/usr/lib/python2.7/dist-packages/django/http/request.py",
>>>>>> [Tue May 22 11:06:14.450998 2018] [wsgi:error] [pid 22853:tid
>>>>>> 139708250121984]     if domain and validate_host(domain, allowed_hosts):
>>>>>> [Tue May 22 11:06:14.451044 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.451104 2018] [wsgi:error] [pid 22853:tid
>>>>>> 139708250121984]     pattern = pattern.lower()
>>>>>> [Tue May 22 11:06:14.451150 2018] [wsgi:error] [pid 22853:tid
>>>>>> 139708250121984] AttributeError: 'NoneType' object has no attribute 'lower'
>>>>>> [Tue May 22 11:06:14.547263 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708149409536] Internal Server Error: /lib/css/lib/css/assets.min.cs
>>>>>> s
>>>>>> [Tue May 22 11:06:14.547468 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708149409536] Traceback (most recent call last):
>>>>>> [Tue May 22 11:06:14.547529 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708149409536]   File "/usr/lib/python2.7/dist-packa
>>>>>> [Tue May 22 11:06:14.547609 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708149409536]     response = middleware_method(request)
>>>>>> [Tue May 22 11:06:14.547661 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.547704 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708149409536]     host = request.get_host()
>>>>>> [Tue May 22 11:06:14.547766 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708149409536]   File "/usr/lib/python2.7/dist-packages/django/http/request.py",
>>>>>> [Tue May 22 11:06:14.547812 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708149409536]     if domain and validate_host(domain, allowed_hosts):
>>>>>> [Tue May 22 11:06:14.547872 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.547920 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708149409536]     pattern = pattern.lower()
>>>>>> [Tue May 22 11:06:14.547966 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708149409536] AttributeError: 'NoneType' object has no attribute 'lower'
>>>>>> [Tue May 22 11:06:14.551263 2018] [wsgi:error] [pid 22853:tid
>>>>>> 139708149409536] Internal Server Error: /lib/css/geonode/css/ux-all.cs
>>>>>> s
>>>>>> [Tue May 22 11:06:14.551382 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.551450 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.551501 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.551552 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.551610 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.551657 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.551700 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.551745 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.551800 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.551844 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.570258 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708141008640] Internal Server Error: /lib/css/geonode/css/ext-compa
>>>>>> tibility.css
>>>>>> [Tue May 22 11:06:14.570448 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.570512 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.570568 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.570617 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.570664 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.570707 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.570752 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.570795 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.570843 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.570889 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.576838 2018] [wsgi:error] [pid 22853:tid
>>>>>> 139708250121984] Internal Server Error: /lib/css/geonode/css/base.css
>>>>>> [Tue May 22 11:06:14.576986 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.577039 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.577086 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.577153 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.577199 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.577244 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.577289 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.577332 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.577390 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.577436 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.590169 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708166194944] Internal Server Error: /lib/css/lib/js/assets.min.js
>>>>>> [Tue May 22 11:06:14.590306 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708166194944] Traceback (most recent call last):
>>>>>> [Tue May 22 11:06:14.590358 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708166194944]   File "/usr/lib/python2.7/dist-packa
>>>>>> [Tue May 22 11:06:14.590406 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708166194944]     response = middleware_method(request)
>>>>>> [Tue May 22 11:06:14.590454 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.590500 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708166194944]     host = request.get_host()
>>>>>> [Tue May 22 11:06:14.590544 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708166194944]   File "/usr/lib/python2.7/dist-packages/django/http/request.py",
>>>>>> [Tue May 22 11:06:14.590601 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708166194944]     if domain and validate_host(domain, allowed_hosts):
>>>>>> [Tue May 22 11:06:14.590648 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.590697 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708166194944]     pattern = pattern.lower()
>>>>>> [Tue May 22 11:06:14.590742 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708166194944] AttributeError: 'NoneType' object has no attribute 'lower'
>>>>>> [Tue May 22 11:06:14.616891 2018] [wsgi:error] [pid 22853:tid
>>>>>> 139708166194944] Internal Server Error: /lib/css/geonode/js/utils/util
>>>>>> s.js
>>>>>> [Tue May 22 11:06:14.617036 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.617091 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.617141 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.617185 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.617234 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.617285 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.617344 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.617396 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.617443 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.617486 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.774256 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708132607744] Internal Server Error: /lib/css/geonode/js/base/base.
>>>>>> js
>>>>>> [Tue May 22 11:06:14.774505 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708132607744] Traceback (most recent call last):
>>>>>> [Tue May 22 11:06:14.774566 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708132607744]   File "/usr/lib/python2.7/dist-packa
>>>>>> [Tue May 22 11:06:14.774615 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708132607744]     response = middleware_method(request)
>>>>>> [Tue May 22 11:06:14.774661 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.774706 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708132607744]     host = request.get_host()
>>>>>> [Tue May 22 11:06:14.774753 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708132607744]   File "/usr/lib/python2.7/dist-packages/django/http/request.py",
>>>>>> [Tue May 22 11:06:14.774809 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708132607744]     if domain and validate_host(domain, allowed_hosts):
>>>>>> [Tue May 22 11:06:14.774874 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.774918 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708132607744]     pattern = pattern.lower()
>>>>>> [Tue May 22 11:06:14.774969 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708132607744] AttributeError: 'NoneType' object has no attribute 'lower'
>>>>>> [Tue May 22 11:06:14.779400 2018] [wsgi:error] [pid 22853:tid
>>>>>> 139708149409536] Internal Server Error: /jsi18n/
>>>>>> [Tue May 22 11:06:14.779527 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.779585 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.779633 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.779677 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.779728 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.779774 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.779817 2018] [wsgi:error] [pid 22853:tid
>>>>>> in, allowed_hosts):
>>>>>> [Tue May 22 11:06:14.779862 2018] [wsgi:error] [pid 22853:tid
>>>>>> ages/django/http/request.py", line 571, in validate_host
>>>>>> [Tue May 22 11:06:14.779911 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.779965 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.807392 2018] [wsgi:error] [pid 22852:tid
>>>>>> 139708166194944] Internal Server Error: /lang.js
>>>>>> [Tue May 22 11:06:14.807575 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.807629 2018] [wsgi:error] [pid 22852:tid
>>>>>> ages/django/core/handlers/base.py", line 108, in get_response
>>>>>> [Tue May 22 11:06:14.807676 2018] [wsgi:error] [pid 22852:tid
>>>>>> uest)
>>>>>> [Tue May 22 11:06:14.807721 2018] [wsgi:error] [pid 22852:tid
>>>>>> ages/django/middleware/common.py", line 62, in process_request
>>>>>> [Tue May 22 11:06:14.807765 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.807813 2018] [wsgi:error] [pid 22852:tid
>>>>>> ages/django/http/request.py", line 94, in get_host
>>>>>> [Tue May 22 11:06:14.807858 2018] [wsgi:error] [pid 22852:tid
>>>>>> in, allowed_hosts):
>>>>>> [Tue May 22 11:06:14.807904 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.807948 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.808009 2018] [wsgi:error] [pid 22852:tid
>>>>>> [Tue May 22 11:06:14.978068 2018] [wsgi:error] [pid 22853:tid
>>>>>> 139708166194944] Internal Server Error: /favicon.ico
>>>>>> [Tue May 22 11:06:14.978270 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.978326 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.978374 2018] [wsgi:error] [pid 22853:tid
>>>>>> uest)
>>>>>> [Tue May 22 11:06:14.978440 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.978492 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.978538 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.978637 2018] [wsgi:error] [pid 22853:tid
>>>>>> in, allowed_hosts):
>>>>>> [Tue May 22 11:06:14.978690 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.978736 2018] [wsgi:error] [pid 22853:tid
>>>>>> [Tue May 22 11:06:14.978788 2018] [wsgi:error] [pid 22853:tid
>>>>>> On Mon, May 21, 2018 at 6:39 PM, Simone Dalmasso <
>>>>>>> Ciao Dimitris. What do you get if you manually request one of those
>>>>>>> css? For the 500 you should see something in the Apache logs.
>>>>>>> Il giorno lun 21 mag 2018 alle 15:47 Dimitris Kar <
>>>>>>>> Hey Toni
>>>>>>>> Yes. I have installed the geonode using apt and in the end I also
>>>>>>>> executed the collectstatic command. I wonder if its related with firewall
>>>>>>>> properties or forwarding of the internal IP to the external etc.
>>>>>>>> _______________________________________________
>>>>>>>> geonode-devel mailing list
>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>> Simone
>>>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180524/860eacbf/attachment-0001.html>
More information about the geonode-devel mailing list
