[GeoNode-devel] [GeoNode-users] GeoNode WorldMap client to be part of GeoNode
francesco bartoli xbartolone at gmail.com
Thu May 31 01:29:11 PDT 2018
+1 thanks Paolo!
Il giorno gio 31 mag 2018 alle ore 10:16 Simone Dalmasso <
simone.dalmasso at gmail.com> ha scritto:
> +1 definitely.
> 2018-05-31 9:59 GMT+02:00 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it>:
>> I have taken a look at the PR and it looks good to me.
>> The module is a contrib module not enabled by default and therefore not
>> affecting the core functionalities at all.
>> Also there are not schema changes on the GeoNode core. Moreover there are
>> a lot of improvements on translations.
>> That said, if no other objection. I am +1 on merging the PR and start the
>> release process ASAP.
>> Let's wait for other feedbacks.
>> Thanks Paolo!
>> 2018-05-31 9:03 GMT+02:00 Dimitris Kar <dkarakostis at gmail.com>:
>>> Thanks Paolo,
>>> Great contribution.
>>> On Thu, May 31, 2018 at 8:08 AM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> Great! Thanks Paolo
>>>> 2018-05-30 21:20 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
>>>>> I forgot to mention that this client extends the GeoNode serialization
>>>>> format. Therefore maps whic are created using the WorldMap client will
>>>>> not
>>>>> be compatible with the default GeoNode client. It should be simple
>>>>> anyway
>>>>> to write a Django command which converts maps back and forth
>>>>> best
>>>>> Paolo
>>>>> On Wed, May 30, 2018 at 3:14 PM Paolo Corti <pcorti at gmail.com> wrote:
>>>>> > Dear GeoNode users and developers
>>>>> > Earlier today I sent a pull request [1] vs the 2.7.x GeoNode branch
>>>>> (to
>>>>> > become GeoNode 2.8.1), which implements this GNIP [2]. This pull
>>>>> request
>>>>> > introduce the Harvard WorldMap contribute application in GeoNode.
>>>>> > You can have a full list of the features introduced from the
>>>>> application
>>>>> at
>>>>> > [2]. In brief this application introduce a new client, based on an
>>>>> improved
>>>>> > version of the GeoExplorer default client, with additional features
>>>>> such
>>>>> as:
>>>>> > * layer categories in table of contents
>>>>> > * layer graduated style editor
>>>>> > * a find place widget and layers gazetteer
>>>>> > * feature search
>>>>> > * map revisions
>>>>> > * URL permalink for maps
>>>>> > * layer search with Hypermap Registry (optional)
>>>>> > The application is optional and does not introduce any change in
>>>>> existing
>>>>> > GeoNode tables. If enabled, it will create a few new tables in
>>>>> GeoNode
>>>>> > database, which are needed in order for the application to work. You
>>>>> must
>>>>> > use PostgreSQL to use this application, and PostgreSQL will require
>>>>> the
>>>>> > PostGIS and dblink extensions.
>>>>> > The GNIP implementation is based on current GeoNode WorldMap source
>>>>> code
>>>>> > [3], and contains code committed by a number of GeoNode developers:
>>>>> > * Matt Bertrand
>>>>> > * Paolo Corti
>>>>> > * Wayner Barrios
>>>>> > * Jorge Martínez Gómez
>>>>> > * Lennin Suescun
>>>>> > * 刘尧 aka Lanni
>>>>> > If there is consensus, this application will be merged in GeoNode
>>>>> source
>>>>> > code as a contribute module.
>>>>> > Thanks
>>>>> > Paolo
>>>>> > [1] https://github.com/GeoNode/geonode/pull/3817
>>>>> > [2] https://github.com/GeoNode/geonode/issues/3718
>>>>> > [3] https://github.com/cga-harvard/geonode/tree/worldmap-2.7.x
>>>>> > Paolo Corti
>>>>> > Geospatial software developer
>>>>> > web: http://www.paolocorti.net
>>>>> > twitter: @capooti
>>>>> > skype: capooti
>>>>> Paolo Corti
>>>>> twitter: @capooti
>>>>> skype: capooti
>>>>> _______________________________________________
>>>>> geonode-devel mailing list
>>>>> geonode-devel at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>> Simone
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A -
>> <https://maps.google.com/?q=Via+di+Montramito+3/A+-++55054+%C2%A0Massarosa&entry=gmail&source=g>55054
>>  Massarosa
>> (LU) - Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180531/71431456/attachment.html>
More information about the geonode-devel mailing list
