[GeoNode-devel] [GeoNode-users] GeoNode WorldMap client to be part of GeoNode
Bernard Justus Muhwezi bernard.muhwezi at gmail.com
Thu May 31 05:04:54 PDT 2018
Dear Team,
+1, appreciation to you.
Bernard Justus
On Wed, May 30, 2018 at 10:14 PM, Paolo Corti <pcorti at gmail.com> wrote:
> Dear GeoNode users and developers
> Earlier today I sent a pull request [1] vs the 2.7.x GeoNode branch (to
> become GeoNode 2.8.1), which implements this GNIP [2]. This pull request
> introduce the Harvard WorldMap contribute application in GeoNode.
> You can have a full list of the features introduced from the application at
> [2]. In brief this application introduce a new client, based on an improved
> version of the GeoExplorer default client, with additional features such
> as:
> * layer categories in table of contents
> * layer graduated style editor
> * a find place widget and layers gazetteer
> * feature search
> * map revisions
> * URL permalink for maps
> * layer search with Hypermap Registry (optional)
> The application is optional and does not introduce any change in existing
> GeoNode tables. If enabled, it will create a few new tables in GeoNode
> database, which are needed in order for the application to work. You must
> use PostgreSQL to use this application, and PostgreSQL will require the
> PostGIS and dblink extensions.
> The GNIP implementation is based on current GeoNode WorldMap source code
> [3], and contains code committed by a number of GeoNode developers:
> * Matt Bertrand
> * Paolo Corti
> * Wayner Barrios
> * Jorge Martínez Gómez
> * Lennin Suescun
> * 刘尧 aka Lanni
> If there is consensus, this application will be merged in GeoNode source
> code as a contribute module.
> Thanks
> Paolo
> [1] https://github.com/GeoNode/geonode/pull/3817
> [2] https://github.com/GeoNode/geonode/issues/3718
> [3] https://github.com/cga-harvard/geonode/tree/worldmap-2.7.x
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180531/b2d7610a/attachment-0001.html>
More information about the geonode-devel mailing list
