[GeoNode-devel] [GeoNode-users] ➜ Two ansible playbooks
Paolo Corti pcorti at gmail.com
Fri Nov 2 08:09:56 PDT 2018
Excellent! Will have a look at this at some point. Could be a great
way to install GeoNode without using containers
best
Paolo
On Fri, Nov 2, 2018 at 3:24 AM Toni Schönbuchner
<toni.schoenbuchner at csgis.de> wrote:
> Dear Community,
> find here two new Ansible playbooks: https://github.com/csgis/geonode_ansible
> which will install/configure geonode 2.8 or master (different branches) on an Ubuntu
> instance. The Setup uses geonode_project, plus the full Tomcat, Apache … stack.
> These Tasks-only playbooks can be used for a quick hit and run
> and do not offer any code reuse opportunities by definition of roles or best practices
> like Ansible directory layout ...
> On the other hand they stay close to the official documentation. Hence it should
> be easy for you to understand what’s happening why and when.
> To get in running (check README)
> 1) install Ansible [1]
> 2) clone the repository
> 3) check that your instance can be reached by use of ssh key auth and that python Is installed.
> 4) setup your instance in the host file
> 5) adjust the vars like Geoserver password etc. to your needs
> 6) get a cup of coffee and let Ansible do the hard work.
> 7) Ansible will fail fast if something goes wrong if not log in with admin/admin and test.
> I´ve tested the playbooks locally and at some AWS Instances
> feedback, problems etc. very welcome !
> Cheers,
> – Toni
> [1] If you never heard about it, ansible is an orchestration software for servers.
> The software runs defined tasks against one or many instances, Installation:
> https://docs.ansible.com/ansible/latest/installation_guide/intro_installation.html
> CSGIS
> Kolonnadenstraße 1
> 04109 Leipzig
> Mobil +49/ (0) 176 6680 3198
> Tel  +49/ (0) 341 24 04 738
> Fax  +49/ (0) 341 24 04 73
> Web http://csgis.de
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung, Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-devel mailing list
