[GeoNode-devel] Docker issue
Francesco Bartoli
xbartolone at gmail.com
Thu Nov 22 09:07:05 PST 2018
Can you please go through this discussion [1] and see if the issue is similar and you ended up with a wrong configuration of your docker-compose deployment?
Regards,
Francesco
Il 22 nov 2018, 17:14 +0100, Pieter du Plooy <pjduplooy.gis at gmail.com>, ha scritto:
> Sorry
> Forgot to add that I am using Geonode master
> > On Thu, Nov 22, 2018 at 5:53 PM Pieter du Plooy <pjduplooy.gis at gmail.com> wrote:
> > > Hi guys.
> > > Have reported this issue on github, but also doing here as I need a solution quite urgently.
> > > "Using Windows 10.
> > > Installation went fine, but having a little issue. When trying to upload a layer, and I select choose files, I can select the files, but it does not show up in the main window, so that I can upload the layer.
> > > Can anyone help me urgently, as I have to do a presentation on Monday on open source Geospatial Technology."
> > > Pieter
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181122/3bca308a/attachment.html>
More information about the geonode-devel
