[GeoNode-devel] Docker issue
Pieter du Plooy
pjduplooy.gis at gmail.com
Thu Nov 22 10:04:29 PST 2018
Hi Francesco
There isn't a link to the discussion you are talking about.
Pieter
On Thu, Nov 22, 2018 at 7:07 PM Francesco Bartoli <xbartolone at gmail.com>
wrote:
> Can you please go through this discussion [1] and see if the issue is
> similar and you ended up with a wrong configuration of your docker-compose
> deployment?
> Regards,
> Francesco
> Il 22 nov 2018, 17:14 +0100, Pieter du Plooy <pjduplooy.gis at gmail.com>,
> ha scritto:
> Sorry
> Forgot to add that I am using Geonode master
> On Thu, Nov 22, 2018 at 5:53 PM Pieter du Plooy <pjduplooy.gis at gmail.com>
> wrote:
>> Hi guys.
>> Have reported this issue on github, but also doing here as I need a
>> solution quite urgently.
>> "Using Windows 10.
>> Installation went fine, but having a little issue. When trying to upload
>> a layer, and I select choose files, I can select the files, but it does not
>> show up in the main window, so that I can upload the layer.
>> Can anyone help me urgently, as I have to do a presentation on Monday on
>> open source Geospatial Technology."
>> Pieter
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181122/1f99d57f/attachment.html>
More information about the geonode-devel
