[GeoNode-devel] Docker issue
Pieter du Plooy pjduplooy.gis at gmail.com
Thu Nov 22 10:28:33 PST 2018
Hi Francesco
I have changed all files using the examples, but the problem is still there
Pieter
On Thu, Nov 22, 2018 at 8:06 PM Francesco Bartoli <xbartolone at gmail.com>
wrote:
> You are right, sorry
> [1]
> http://osgeo-org.1560.x6.nabble.com/Re-geonode-users-Digest-Vol-46-Issue-22-td5386156.html
> Regards,
> Francesco
> Il 22 nov 2018, 19:04 +0100, Pieter du Plooy <pjduplooy.gis at gmail.com>,
> ha scritto:
> Hi Francesco
> There isn't a link to the discussion you are talking about.
> Pieter
> On Thu, Nov 22, 2018 at 7:07 PM Francesco Bartoli <xbartolone at gmail.com>
> wrote:
>> Can you please go through this discussion [1] and see if the issue is
>> similar and you ended up with a wrong configuration of your docker-compose
>> deployment?
>> Regards,
>> Francesco
>> Il 22 nov 2018, 17:14 +0100, Pieter du Plooy <pjduplooy.gis at gmail.com>,
>> ha scritto:
>> Sorry
>> Forgot to add that I am using Geonode master
>> On Thu, Nov 22, 2018 at 5:53 PM Pieter du Plooy <pjduplooy.gis at gmail.com>
>> wrote:
>>> Hi guys.
>>> Have reported this issue on github, but also doing here as I need a
>>> solution quite urgently.
>>> "Using Windows 10.
>>> Installation went fine, but having a little issue. When trying to upload
>>> a layer, and I select choose files, I can select the files, but it does not
>>> show up in the main window, so that I can upload the layer.
>>> Can anyone help me urgently, as I have to do a presentation on Monday on
>>> open source Geospatial Technology."
>>> Pieter
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181122/f67da4ef/attachment.html>
More information about the geonode-devel mailing list
