[GeoNode-devel] Docker issue
Francesco Bartoli
xbartolone at gmail.com
Thu Nov 22 10:32:44 PST 2018
Can you describe what kind of configuration has been done after cloning GeoNode?
Thanks,
Francesco
Il 22 nov 2018, 19:28 +0100, Pieter du Plooy <pjduplooy.gis at gmail.com>, ha scritto:
> Hi Francesco
> I have changed all files using the examples, but the problem is still there
> Pieter
> > On Thu, Nov 22, 2018 at 8:06 PM Francesco Bartoli <xbartolone at gmail.com> wrote:
> > > You are right, sorry
> > > [1] http://osgeo-org.1560.x6.nabble.com/Re-geonode-users-Digest-Vol-46-Issue-22-td5386156.html
> > > Regards,
> > > Francesco
> > > Il 22 nov 2018, 19:04 +0100, Pieter du Plooy <pjduplooy.gis at gmail.com>, ha scritto:
> > > > Hi Francesco
> > > > There isn't a link to the discussion you are talking about.
> > > > Pieter
> > > > > On Thu, Nov 22, 2018 at 7:07 PM Francesco Bartoli <xbartolone at gmail.com> wrote:
> > > > > > Can you please go through this discussion [1] and see if the issue is similar and you ended up with a wrong configuration of your docker-compose deployment?
> > > > > > Regards,
> > > > > > Francesco
> > > > > > Il 22 nov 2018, 17:14 +0100, Pieter du Plooy <pjduplooy.gis at gmail.com>, ha scritto:
> > > > > > > Sorry
> > > > > > > Forgot to add that I am using Geonode master
> > > > > > > > On Thu, Nov 22, 2018 at 5:53 PM Pieter du Plooy <pjduplooy.gis at gmail.com> wrote:
> > > > > > > > > Hi guys.
> > > > > > > > > Have reported this issue on github, but also doing here as I need a solution quite urgently.
> > > > > > > > > "Using Windows 10.
> > > > > > > > > Installation went fine, but having a little issue. When trying to upload a layer, and I select choose files, I can select the files, but it does not show up in the main window, so that I can upload the layer.
> > > > > > > > > Can anyone help me urgently, as I have to do a presentation on Monday on open source Geospatial Technology."
> > > > > > > > > Pieter
> > > > > > > _______________________________________________
> > > > > > > geonode-devel mailing list
> > > > > > > geonode-devel at lists.osgeo.org
> > > > > > > https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181122/aa98b0d8/attachment.html>
More information about the geonode-devel
