[GeoNode-devel] Docker issue
Pieter du Plooy pjduplooy.gis at gmail.com
Thu Nov 22 10:42:41 PST 2018
Hi Francesco
It seems that I have made a small mistake in the change of django.env.  I
forgot the ip address.
Thanks.
Working now.
Thanks again.
Pieter
On Thu, Nov 22, 2018 at 8:32 PM Francesco Bartoli <xbartolone at gmail.com>
wrote:
> Can you describe what kind of configuration has been done after cloning
> GeoNode?
> Thanks,
> Francesco
> Il 22 nov 2018, 19:28 +0100, Pieter du Plooy <pjduplooy.gis at gmail.com>,
> ha scritto:
> Hi Francesco
> I have changed all files using the examples, but the problem is still there
> Pieter
> On Thu, Nov 22, 2018 at 8:06 PM Francesco Bartoli <xbartolone at gmail.com>
> wrote:
>> You are right, sorry
>> [1]
>> http://osgeo-org.1560.x6.nabble.com/Re-geonode-users-Digest-Vol-46-Issue-22-td5386156.html
>> Regards,
>> Francesco
>> Il 22 nov 2018, 19:04 +0100, Pieter du Plooy <pjduplooy.gis at gmail.com>,
>> ha scritto:
>> Hi Francesco
>> There isn't a link to the discussion you are talking about.
>> Pieter
>> On Thu, Nov 22, 2018 at 7:07 PM Francesco Bartoli <xbartolone at gmail.com>
>> wrote:
>>> Can you please go through this discussion [1] and see if the issue is
>>> similar and you ended up with a wrong configuration of your docker-compose
>>> deployment?
>>> Regards,
>>> Francesco
>>> Il 22 nov 2018, 17:14 +0100, Pieter du Plooy <pjduplooy.gis at gmail.com>,
>>> ha scritto:
>>> Sorry
>>> Forgot to add that I am using Geonode master
>>> On Thu, Nov 22, 2018 at 5:53 PM Pieter du Plooy <pjduplooy.gis at gmail.com>
>>> wrote:
>>>> Hi guys.
>>>> Have reported this issue on github, but also doing here as I need a
>>>> solution quite urgently.
>>>> "Using Windows 10.
>>>> Installation went fine, but having a little issue. When trying to
>>>> upload a layer, and I select choose files, I can select the files, but it
>>>> does not show up in the main window, so that I can upload the layer.
>>>> Can anyone help me urgently, as I have to do a presentation on Monday
>>>> on open source Geospatial Technology."
>>>> Pieter
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181122/965e5013/attachment-0001.html>
More information about the geonode-devel mailing list
