[GeoNode-devel] [GeoNode-users] [Preview] MapStore2 REACT client for GeoNode
Stefan Steiniger
ssteiniger at uc.cl
Tue Oct 9 13:35:03 PDT 2018
Well done!
However, a comment. When i tested and clicked on expanding the metadata
info below the map the mapwidget itself disapeared (using the us states
layer).
On page reload it came back again.
Cheers,
Stefan
On Tue, Oct 9, 2018, 12:30 francesco bartoli, <xbartolone at gmail.com> wrote:
> Awesome job Alessio!
> Congratulations to all the team from GeoSolutions.
> Francesco
> Il giorno mar 9 ott 2018 alle ore 14:22 Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Wonderful job Alessio.
>> I have worked on some APPS in order to provide popups and information
>> (metadata) over the map icons, If I am not misunderstanding, GeoNode
>> improvement is providing these features.
>> Awesome Job!!!
>> Congratulations!!!
>> Kind regards
>> Julierme
>> On Tue, Oct 9, 2018 at 9:04 AM Tom Kralidis <tom.kralidis at gmail.com>
>> wrote:
>>> Thanks Alessio, makes sense. I was wondering about the CSW client
>>> (JavaScript) capabilities being reusable?
>>> On Tue, Oct 9, 2018 at 8:02 AM Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> wrote:
>>>> Hi Tom,
>>>> currently, GeoNode is relying on pycsw==2.2.0 by default to provide CSW
>>>> capabilities.
>>>> In general, GeoNode is trying to be as much as possible compliant with
>>>> the standard OGC services.
>>>> Il giorno mar 9 ott 2018 alle ore 13:45 Tom Kralidis <
>>>> tom.kralidis at gmail.com> ha scritto:
>>>>> Alessio: thanks for the info -- great work here!
>>>>> Is any of the CSW functionality reusable by other applications?
>>>>> ..Tom
>>>>> On Tue, Oct 9, 2018 at 5:32 AM Alessio Fabiani <
>>>>>> Dear all,
>>>>>> we <https://www.geo-solutions.it/> are excited to announce the
>>>>>> (almost complete) integration of MapStore
>>>>>> <https://www.geo-solutions.it/technologies/mapstore/> REACT gis
>>>>>> client with GeoNode <http://geonode.org/>.
>>>>>> Give it a try @ http://dev.geonode.geo-solutions.it/
>>>>>> This is a preview, the latest functionalities are almost complete and
>>>>>> will be available soon, like the brand new improved SLD editor, support for
>>>>>> ArcGIS layers and revamped Time Slider for temporal series.
>>>>>> *Features*
>>>>>> - Easy to install and integrate. With very few steps you can
>>>>>> easily switch your GeoNode gis client to the new one, for more details see:
>>>>>> https://github.com/geosolutions-it/geonode-mapstore-client#integrating-into-geonodedjango
>>>>>> - Perfectly integrated with the GeoNode layout
>>>>>> [image: image.png]
>>>>>> You can benefit from most of the MapStore advanced features, like:
>>>>>> 1. Improved Table of Content
>>>>>> [image: image.png]
>>>>>> 2. Advanced Feature Grid with live filtering
>>>>>> [image: image.png]
>>>>>> 3. Integration with GeoNode CSW Catalog
>>>>>> [image: image.png]
>>>>>> 4. Add custom thumbnail to your maps
>>>>>> [image: image.png]
>>>>>> 5. Advanced Feature Editor
>>>>>> [image: image.png]
>>>>>> 6. Add widgets to the Maps
>>>>>> [image: image.png]
>>>>>> [image: image.png]
>>>>>> And much more...
>>>>>> - Easy to switch JS client library from MapStore between OL3,
>>>>>> Leaflet, and others (see MapStore Documentation for more details)
>>>>>> - 3D view plugins (see MapStore Documentation for more details)
>>>>>> - Possibility to add more widgets and plugins (see MapStore
>>>>>> - Up to date front-end libraries (see MapStore Documentation for
>>>>>> more details)
>>>>>> *Coming soon...*
>>>>>> 1. Refactored SLD Editor with a lot more functionalities
>>>>>> 2. Refactored Time Slider and Time Bar
>>>>>> 3. Integration of ArcGIS layer sources
>>>>>> The first release will be available very soon.
>>>>>> Stay tuned.
>>>>>> Cheers,
>>>>>> Alessio Fabiani and the MapStore Team.
>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>> http://goo.gl/it488V for more information.
>>>>>> Ing. Alessio Fabiani
>>>>>> @alfa7691
>>>>>> Founder/Technical Lead
>>>>>> GeoSolutions S.A.S.
>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>> phone: +39 0584 962313
>>>>>> fax: +39 0584 1660272
>>>>>> mob: +39 331 6233686
>>>>>> http://www.geo-solutions.it
>>>>>> http://twitter.com/geosolutions_it
>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>> This email is intended only for the person or entity to which it is
>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>> notify us immediately by telephone or e-mail.
>>>>>> _______________________________________________
>>>>>> geonode-devel mailing list
>>>>>> geonode-devel at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181009/27a60bc1/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181009/27a60bc1/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181009/27a60bc1/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181009/27a60bc1/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181009/27a60bc1/attachment-0011.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181009/27a60bc1/attachment-0012.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181009/27a60bc1/attachment-0013.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181009/27a60bc1/attachment-0014.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181009/27a60bc1/attachment-0015.png>
More information about the geonode-devel
