[GeoNode-devel] hibernate-spatial-postgis
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Oct 24 01:06:12 PDT 2018
That issue has been fixed on GeoServer 2.15.x, but there GeoFence has been
promoted as an official extension.
Adding to that, GeoServer Community Release packaging has some general
issues, and the jars are not correctly assembled.
Probably the easiest way is to move to GeoServer 2.15.x, hence it is mostly
the same as 2.14.x with few important updates and fixes either on GeoFence
and the Importer.
I'll evaluate this option as soon as the stability tests are finished.
Il giorno mar 23 ott 2018 alle ore 17:09 Paolo Corti <pcorti at gmail.com> ha
scritto:
> Update: I found hibernate-spatial-1.1.3.1.jar in the Boundless
> repository, as suggested here
> https://mvnrepository.com/artifact/org.hibernatespatial/hibernate-spatial-postgis/1.1.3.1
> Alessio, Francesco: I am wondering if this could be included in the
> GeoServer build process for GeoNode.
> Thanks
> Paolo
> On Tue, Oct 23, 2018 at 10:18 AM Paolo Corti <pcorti at gmail.com> wrote:
> > Hi developers
> > I am trying to use GeoFence with PostGIS using latest GeoNode
> > (GeoServer 2.14.x). I see that the war comes with
> > hibernate-spatial-1.1.3.1.jar and
> > hibernate-spatial-h2-geodb-1.1.3.1.jar which works well if using H2,
> > the default GeoFence database. But when using PostGIS I can't find an
> > hibernate-spatial-postgis-1.1.3.jar to use, and the one I can find on
> > maven repository, hibernate-spatial-postgis-1.1.1.jar, looks to be
> > incompatible (GeoServer won't start because of this).
> > I can successfully start GeoServer using
> > hibernate-spatial-postgis-1.1.1.jar and replacing
> > hibernate-spatial-1.1.3.1.jar with hibernate-spatial-1.1.1.jar, but I
> > am wondering if could cause any issue. Any thoughts on this?
> > Thanks!
> > Paolo
> > Paolo Corti
> > Geospatial software developer
> > web: http://www.paolocorti.net
> > twitter: @capooti
> > skype: capooti
> Paolo Corti
> twitter: @capooti
> skype: capooti
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181024/07c7df0b/attachment.html>
More information about the geonode-devel mailing list
