[GeoNode-devel] Switching to MapStore in GeoNode
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Apr 1 09:39:23 PDT 2019
P.S.: it works only with GeoNode 2.10+
Il giorno lun 1 apr 2019 alle ore 18:36 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> That is quite strange. Have you been able to get a stacktrace somehow?
> Maybe try to comment the "GEONODE_CLIENT_HOOKSET" in order to check that
> the exception does not occur or it is hidden by another one.
> Il giorno lun 1 apr 2019 alle ore 18:13 Paolo Pasquali <
> paolo.pasquali at gmail.com> ha scritto:
>> Ciao Alessio,
>> My settings section starts with:
>> # To enable the MapStore2 based Client enable those
>> if 'geonode_mapstore_client' not in INSTALLED_APPS:
>>     INSTALLED_APPS += (
>>         'mapstore2_adapter',
>>         'geonode_mapstore_client',)
>> GEONODE_CLIENT_LAYER_PREVIEW_LIBRARY = 'mapstore'  # DEPRECATED use
>> HOOKSET instead
>> GEONODE_CLIENT_HOOKSET =
>> "geonode_mapstore_client.hooksets.MapStoreHookSet"
>> Thanks,
>> P.
>> Paolo Pasquali
>> ITHACA - Information Technology for Humanitarian Assistance, Cooperation
>> and Action
>> via Pier Carlo Boggio, 61
>> 10138 Torino - Italy
>> Tel. +39 011 1975 1872
>> Fax +39 011 1975 1122
>> On Mon, Apr 1, 2019 at 5:53 PM Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> wrote:
>>> Hello Paolo,
>>> can you check if the before the Hookset you have the following sentence
>>> in your settings file
>>>     INSTALLED_APPS += (
>>> Il giorno lun 1 apr 2019 alle ore 17:45 Paolo Pasquali <
>>>> Dear all,
>>>> I would like to test MapStore in GeoNode. I've followed the
>>>> instructions [1] and removed the related comments in my settings but I get:
>>>> ImportError: No module named mapstore2_adapter
>>>> Double checking:
>>>> $ pip show django-mapstore-adapter
>>>> Version: 0.1.13
>>>> Summary: Django MapStore2 Adapter
>>>> Home-page: https://github.com/geosolutions-it/django-mapstore-adapter
>>>> Author: Alessio Fabiani
>>>> Author-email: alessio.fabiani at geo-solutions.it
>>>> License: UNKNOWN
>>>> Location:
>>>> /Users/paolo/Documents/workspaces/teragrop/lib/python2.7/site-packages
>>>> Requires: Markdown, requests, django, jsonfield, djangorestframework,
>>>> idna, MarkupSafe
>>>> Required-by: django-geonode-mapstore-client
>>>> And
>>>> $ pip show django-geonode-mapstore-client
>>>> Version: 0.1.18
>>>> Summary: Use GeoNode client in your django projects
>>>> Home-page: https://github.com/GeoNode/geonode-mapstore-client
>>>> Author-email: alessio.fabiani at gmail.com
>>>> License: BSD, see LICENSE file.
>>>> Location:
>>>> Requires: django-mapstore-adapter
>>>> Required-by:
>>>> Thanks in advance for your help.
>>>> Best,
>>>> Paolo
>>>> [1]
>>>> https://github.com/geosolutions-it/geonode-mapstore-client#integrating-into-geonodedjango
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190401/b25516c7/attachment-0001.html>
More information about the geonode-devel mailing list
