[GeoNode-devel] Switching to MapStore in GeoNode
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Apr 1 09:36:30 PDT 2019
That is quite strange. Have you been able to get a stacktrace somehow?
Maybe try to comment the "GEONODE_CLIENT_HOOKSET" in order to check that
the exception does not occur or it is hidden by another one.
Il giorno lun 1 apr 2019 alle ore 18:13 Paolo Pasquali <
paolo.pasquali at gmail.com> ha scritto:
> Ciao Alessio,
> My settings section starts with:
> # To enable the MapStore2 based Client enable those
> if 'geonode_mapstore_client' not in INSTALLED_APPS:
>     INSTALLED_APPS += (
>         'mapstore2_adapter',
>         'geonode_mapstore_client',)
> GEONODE_CLIENT_LAYER_PREVIEW_LIBRARY = 'mapstore'  # DEPRECATED use
> HOOKSET instead
> GEONODE_CLIENT_HOOKSET = "geonode_mapstore_client.hooksets.MapStoreHookSet"
> Thanks,
> P.
> Paolo Pasquali
> ITHACA - Information Technology for Humanitarian Assistance, Cooperation
> and Action
> via Pier Carlo Boggio, 61
> 10138 Torino - Italy
> Tel. +39 011 1975 1872
> Fax +39 011 1975 1122
> On Mon, Apr 1, 2019 at 5:53 PM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Hello Paolo,
>> can you check if the before the Hookset you have the following sentence
>> in your settings file
>>     INSTALLED_APPS += (
>> Il giorno lun 1 apr 2019 alle ore 17:45 Paolo Pasquali <
>>> Dear all,
>>> I would like to test MapStore in GeoNode. I've followed the instructions
>>> [1] and removed the related comments in my settings but I get:
>>> ImportError: No module named mapstore2_adapter
>>> Double checking:
>>> $ pip show django-mapstore-adapter
>>> Version: 0.1.13
>>> Summary: Django MapStore2 Adapter
>>> Home-page: https://github.com/geosolutions-it/django-mapstore-adapter
>>> Author: Alessio Fabiani
>>> Author-email: alessio.fabiani at geo-solutions.it
>>> License: UNKNOWN
>>> Location:
>>> /Users/paolo/Documents/workspaces/teragrop/lib/python2.7/site-packages
>>> Requires: Markdown, requests, django, jsonfield, djangorestframework,
>>> idna, MarkupSafe
>>> Required-by: django-geonode-mapstore-client
>>> And
>>> $ pip show django-geonode-mapstore-client
>>> Version: 0.1.18
>>> Summary: Use GeoNode client in your django projects
>>> Home-page: https://github.com/GeoNode/geonode-mapstore-client
>>> Author-email: alessio.fabiani at gmail.com
>>> License: BSD, see LICENSE file.
>>> Location:
>>> Requires: django-mapstore-adapter
>>> Required-by:
>>> Thanks in advance for your help.
>>> Best,
>>> Paolo
>>> [1]
>>> https://github.com/geosolutions-it/geonode-mapstore-client#integrating-into-geonodedjango
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190401/365e20cb/attachment-0001.html>
More information about the geonode-devel mailing list
